I can't configure where the problem is in the connection between the arduino and OBDLink SX
Hi! for my project, i'm using the OBDLink SX as my OBD2 cable and i'm connecting it to a USB-to-TTL adapter(FT232BL) so i can connect to the arduino through the TX and RX pins. for my code i'm using the ELM327 library (GitHub - PowerBroker2/ELMduino: Arduino OBD-II Bluetooth Scanner Interface Library for Car Hacking Projects). Now when i upload the code, this is what the serial monitor displays:
Attempting to connect to ELM327...
Clearing input serial buffer
Sending the following command/query: AT D
Timeout detected with overflow of 0ms
Sending the following command/query: AT Z
Sending the following command/query: AT E0
Sending the following command/query: AT S0
Sending the following command/query: AT AL
Timeout detected with overflow of 1ms
Sending the following command/query: AT ST 00
Sending the following command/query: AT SP A0
Setting protocol via AT TP A%c did not work - trying via AT SP %c
Sending the following command/query: AT SP 0
Setting protocol via AT SP %c did not work
Couldn't connect to OBD scanner
Connected to ELM327
Service: 1
PID: 5
Normal length query detected
Query string: 01051
Sending the following command/query: 01051
Timeout detected with overflow of 1000ms
Service: 1
PID: 12
Query string: 010C1
Sending the following command/query: 010C1
Service: 1
PID: 12
and this is the code that i'm using :
#include "ELMduino.h"
#include <SoftwareSerial.h>
// Define the pins for SoftwareSerial
#define ELM_TX_PIN 10 // Arduino pin to ELM327 Rx
#define ELM_RX_PIN 11 // Arduino pin to ELM327 Tx
SoftwareSerial elmSerial(ELM_RX_PIN, ELM_TX_PIN); // RX, TX
#define ELM_PORT elmSerial
const bool DEBUG = true;
const int TIMEOUT = 2000;
const bool HALT_ON_FAIL = false;
ELM327 myELM327;
  Serial.begin(115200); // Start the hardware serial for debugging
  ELM_PORT.begin(115200); // Start the SoftwareSerial for ELM327
  Serial.println("Attempting to connect to ELM327...");
  if (!myELM327.begin(ELM_PORT, DEBUG, TIMEOUT)) {
    Serial.println("Couldn't connect to OBD scanner");
    if (HALT_ON_FAIL) {
      while (1);
  Serial.println("Connected to ELM327");
  float coolantTemp = myELM327.engineCoolantTemp();
  float rpm = myELM327.rpm();
  float speed = myELM327.kph();
  if (myELM327.nb_rx_state == ELM_SUCCESS) {
    Serial.print("Temperature: ");
    Serial.println(coolantTemp);
    Serial.print("RPM: ");
    Serial.println(rpm);
    Serial.print("Speed: ");
    Serial.println(speed);
    // Send data in a single line for easy parsing
    Serial.print("DATA,");
    Serial.print(coolantTemp);
    Serial.print(",");
    Serial.print(rpm);
    Serial.print(",");
  } else if (myELM327.nb_rx_state != ELM_GETTING_MSG) {
    myELM327.printError();
  delay(1000); // Adjust delay as needed
ps i'm using digital tx and rx pins because according to what i read the "original" tx and rx pins are used for the connection to my pc and debugging. pls help i'mm really confused
