Post your arduino sketch here and may be some one can help.
15.16.17.18 could be an example IP address in a configuration file which you have forgotten to change.
I hate it when people post screenshots with scroll bars in them ... it confuses me when I try to use them!
(your image is also a bmp file named as a jpg). Not sure what your problem it, but the 15,16,17,18 sure has the feel of an index or something that you are getting instead of what it was supposed to point at.
sorry about the picture..i just screenshot it in my computer and also i think i should rephrase my problem
i tried this code which was posted in the examples
#include <SPI.h>
#include <Ethernet.h>
// network configuration. dns server, gateway and subnet are optional.
// the media access control (ethernet hardware) address for the shield:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// the dns server ip
IPAddress dnServer(192, 168, 1, 1);
// the router's gateway address:
IPAddress gateway(192, 168, 1, 1);
// the subnet:
IPAddress subnet(255, 255, 255, 0);
//the IP address is dependent on your network
IPAddress ip(192, 168, 1, 8);
// initialize the ethernet device
Ethernet.begin(mac, ip, dnServer, gateway, subnet);
//print out the IP address
Serial.print("IP = ");
Serial.println(Ethernet.localIP());
and my output is
IP = 15.16.17.18
so my problem is..it should display the ip address you inputed but it shows different..and i research about it in google and found out it on NAT which is i dont understand and dont wanna go deeper..im only just trying to connect and get the data from arduino to php.
"sorry about the picture..i just screenshot it in my computer and also i think i should rephrase my problem" - yes, I know - I was poking fun at myself. I managed to do that all the time - grab a screenshot then forget I am looking at a screen shot and try to click or scroll something. :o
NAT is something that goes on (typically) in your router between the local network (LAN - in your house for example) and the outside world (WAN) It converts private addresses on the LAN (192.168.?.? or 10.?.?.? for example) to addresses for the internet. Think of it as the switchboard for a big company - you can only call in on a couple of numbers, but those can be connected to thousands of employees by the switchboard. Sort of. A bit more complex than that, but that is the basics of what NAT (Network Address Translation) does. All the machines on your local network (LAN) should have similar numbers - like 192.168.1.? for example (and typically the router will have 192.168.1.1 as it's LAN side.)
ok it seems i got printing it somehow like 192.168.1.8 as anything i putted in my IPaddress..but the next problem is when i try this code
Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe, based on work by Adrian McEwen
#include <SPI.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server[] = "www.google.com"; // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
// the subnet:
IPAddress ip(192, 168, 1, 6);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
pinMode(4, OUTPUT);
digitalWrite(4, HIGH);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// try to congifure using IP address instead of DHCP:
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET /search?q=arduino HTTP/1.1");
client.println("Host: www.google.com");
client.println("Connection: close");
client.println();
// if you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
while (true);
it prints out like this
connecting...
connected
ok i got it working now. i got some respone in google with this code
#include <SPI.h>
IPAddress ip(192,168,1,6);
IPAddress server(192,168,1,1);
// disable SD card if one in the slot
pinMode(4,OUTPUT);
digitalWrite(4,HIGH);
Serial.println("Starting w5100");
Ethernet.begin(mac,ip);
Serial.println("Connecting to google....");
int ret;
if (ret = client.connect(server, 80)) {
client.println();
else {
// kf you didn't get a connection to the server:
Serial.println(ret);
Serial.print(c);
client.stop();
while(true);
so ok thx for letting me understand the addresses
and now can anyone give some short code for sending data to php ?
for example if have like this.
Take a look at the GET http if you are not concerned about sensitive data (it is part of the URL when it sends it, but it makes it easy to debug). Here are a couple of links to check out:
