I cant explain this.
Hi all,
I am very new to Arduino. I took some coding classes in high school 10 years ago and haven't touched it since.... BUuuut this doesn't seem to be a coding problem. I've got my Uno wired and programed to have an LED on and shut off when you press a button, but the light just shuts off when ever it feels like it and more often when I move my hand close to it. I've tried different jumpers, LED's, terminals on the arduino (and changed the programming to match), power through USB and 9V. This is baffling me. I cant figure it out. HELP!!! I uploaded a Youtube video of the problem too see attached
int switchstate = 0;
pinMode(3, OUTPUT);
pinMode(7, INPUT);
switchstate = digitalRead(7);
if (switchstate == LOW)
digitalWrite(3, LOW);
digitalWrite(3, HIGH);
You need a pullup or pulldown resistor on your input pin, to force it to be high or low respectively, when it's not pressed. Easiest way is to use the built-in pullup (there's no builtin pulldown) in code by changing this:
pinMode(7, INPUT);
to this:
pinMode(7, INPUT_PULLUP);
