i can't find it
when i go into the bord list to learn how to use it my bord isn't there.and i have the little bits bord.
These steps may also save you some unnecessary time and effort in the forum.
  • Always provide as much detail as possible to your issue it may be important.
  • If applicable provide your SKETCH inside CODE TAGS ( </> ) or a CREATE share link.
  • If applicable provide a schematic even if hand drawn.
  • Pictures are an invaluable aid. See THIS TOPIC for help posting them.
COMMON ISSUES
  • Check you have a COMMON GROUND where required.
  • Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
  • Try other computers where possible.
  • Try other USB leads where possible.
  • You may not have the correct driver installed. CH340/341 or CP2102
  • There may be a problem with the board check your wiring first.
  • Remove any items connected to pins 0 and 1.
COMPUTER RELATED
  • Ensure you turn off any additional security / antivirus just to test.
  • There may be a problem with the PC try RESTARTING it.
  • You may be selecting the wrong COM port.
  • Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
  • Clear your browsers CACHE.
  • If using CREATE then try and INCOGNITO window or similar to rule out browser add-on's.
  • Close the IDE before using any other serial programs.
  • Preferably install IDE's as ADMINISTRATOR or your OS equivalent
  • If you have tried multiple IDE's then you may need to perform additional clean up.
Performing the above actions may help resolve your problem without further help.
Why do I offer so many help items ?
Because you provided so little detail.
Bob.
If you GOOGLE little bit board it should be listed in the IDE's as a LEONARDO.
Dont forget to select the correct COM port too !
