the link i follow to get those attention and meditation level.
circuit connection :
arduino mega2560 ------- bluetooth module BC417
- vcc(5v) ----- ------- vcc
2.gnd --------------- gnd - tx (tx0) -------------rx
- rx ( rx0 )--------------tx
after wearing the head set the poor quality level is reducing 200 to 0 but the attention and meditation level remains always 0 since last packet is always more than 1500 ms.
#define BAUDRATE 57600
#define DEBUGOUTPUT 0
#define powercontrol 10
// checksum variables
byte generatedChecksum = 0;
byte checksum = 0;
int payloadLength = 0;
byte payloadData[64] = {0};
byte poorQuality = 0;
byte attention = 0;
byte meditation = 0;
// system variables
long lastReceivedPacket = 0;
boolean bigPacket = false;
Serial.begin(BAUDRATE); // USB
byte ReadOneByte()
int ByteRead;
while(!Serial.available());
ByteRead = Serial.read();
#if DEBUGOUTPUT
Serial.print((char)ByteRead); // echo the same byte out the USB serial (for debug purposes)
#endif
return ByteRead;
// Look for sync bytes
if(ReadOneByte() == 170)
payloadLength = ReadOneByte();
if(payloadLength > 169) //Payload length can not be greater than 169
return;
for(int i = 0; i < payloadLength; i++)
payloadData = ReadOneByte(); //Read payload into memory
generatedChecksum += payloadData;
checksum = ReadOneByte(); //Read checksum byte from stream
generatedChecksum = 255 - generatedChecksum; //Take one's compliment of generated checksum
if(checksum == generatedChecksum)
poorQuality = 200;
attention = 0;
meditation = 0;
{ // Parse the payload
switch (payloadData)
case 2:
i++;
poorQuality = payloadData;
bigPacket = true;
case 4:
i++;
attention = payloadData;
case 5:
i++;
meditation = payloadData;
case 0x80:
i = i + 3;
case 0x83:
i = i + 25;
default:
} // switch
} // for loop
#if !DEBUGOUTPUT
// *** Add your code here ***
if(bigPacket)
Serial.print("PoorQuality: ");
Serial.print(poorQuality, DEC);
Serial.print(" Attention: ");
Serial.print(attention, DEC);
Serial.print(" Time since last packet: ");
Serial.print(millis() - lastReceivedPacket, DEC);
lastReceivedPacket = millis();
Serial.print("\n");
switch(attention / 10)
#endif
bigPacket = false;
else {
// Checksum Error
} // end if else for checksum
} // end if read 0xAA byte
