I am using a BEETLE LEONARDO USB ATMEGA32U4 DEVELOPMENT BOARD with a ADS1115 over I2C to create a 4 axis HID game controller. That was fun to get set up, this is my first Arduino project so I'm super new to all of this.
#include <Wire.h>
#include <Arduino.h>
#include <Adafruit_ADS1015.h>
#define I2Caddress 0x48
Adafruit_ADS1115 ads;
#include <Joystick.h>
//Serial.begin(9600);
ads.begin();
Wire.begin();
Joystick.begin();}
{int16_t adc0, adc1, adc2, adc3;
adc0 = ads.readADC_SingleEnded(0);
adc1 = ads.readADC_SingleEnded(1);
adc2 = ads.readADC_SingleEnded(2);
adc3 = ads.readADC_SingleEnded(3);
//Serial.println(adc0); Serial.println(adc1); Serial.println(adc2); Serial.println(adc3); Serial.println(" ");
//delay(255);
int hbrake = map(adc0,1690,23000,0,65535);
int accel = map(adc1,1690,23000,0,65535);
int brake = map(adc2,1690,23000,0,65535);
int clutch = map(adc3,1690,23000,0,65535);
{Joystick.setThrottle(hbrake);}
{Joystick.setXAxisRotation(accel);}
{Joystick.setYAxisRotation(brake);}
{Joystick.setRudder(clutch);}
I have been calibrating it with a old 5v senor (0.5-4.5v) I had laying around until i get my pressure transducer setup, so I've set the limits for this potentiometer and doubled it up from the 15 bit ads11115 to 16 bit readout to windows. I have taken some joystick HID code and have been removing the buttons and hat switches. I am having troubles getting the Y and X rotation to work correctly in game and the windows calibration screen. I was able to get my Throttle and Rudder to work correctly from 0-65535 (raw data value) and it displays a % in the blue bar of the windows calibration screen. The X an Y rotation raw data is reading 0-65535 but the blue bar shows a number value instead of a %.
#include "Joystick.h"
#if defined(_USING_HID)
#define JOYSTICK_REPORT_ID 0x03
#define JOYSTICK_STATE_SIZE 8
static const uint8_t _hidReportDescriptor[] PROGMEM = {
// Joystick
0x05, 0x01, // USAGE_PAGE (Generic Desktop)
0x09, 0x04, // USAGE (Joystick)
0xa1, 0x01, // COLLECTION (Application)
0x85, JOYSTICK_REPORT_ID, // REPORT_ID (3)
// 16 bit Throttle and Steering
0x05, 0x02, // USAGE_PAGE (Simulation Controls)
0x15, 0x00, // LOGICAL_MINIMUM (0)
0x27, 0xff, 0xff, 0x00, 0x00, // LOGICAL_MAXIMUM (65535)
0xA1, 0x00, // COLLECTION (Physical)
0x09, 0xBB, // USAGE (Throttle)
0x09, 0xBA, // USAGE (Rudder)
0x75, 0x10, // REPORT_SIZE (16)
0x95, 0x02, // REPORT_COUNT (2)
0x81, 0x02, // INPUT (Data,Var,Abs)
0xc0, // END_COLLECTION
// rx, ry, Axis
0x05, 0x01, // Usage Page (Generic Desktop)
//0x09, 0x01, // Usage (Pointer)
//0x35, 0x00, // Physical Minimum (0)
//0x47, 0xff, 0xff, 0x00, 0x00, // Physical Maximum (360)
0x09, 0x33, // USAGE (rx)
0x09, 0x34, // USAGE (ry)
0xc0 // END_COLLECTION
Joystick_::Joystick_()
// Setup HID report structure
static HIDSubDescriptor node(_hidReportDescriptor, sizeof(_hidReportDescriptor));
HID().AppendDescriptor(&node);
// Initalize State
xAxisRotation = 0;
yAxisRotation = 0;
throttle = 0;
rudder = 0;
void Joystick_::begin(bool initAutoSendState)
autoSendState = initAutoSendState;
sendState();
void Joystick_::end()
void Joystick_::setThrottle(uint16_t value)
throttle = value;
if (autoSendState) sendState();
void Joystick_::setRudder(uint16_t value)
rudder = value;
void Joystick_::setXAxisRotation(uint16_t value)
xAxisRotation = value;
void Joystick_::setYAxisRotation(uint16_t value)
yAxisRotation = value;
void Joystick_::sendState()
uint8_t data[JOYSTICK_STATE_SIZE];
data[0] = throttle; //lsb
data[1] = throttle >> 8; //msb
data[2] = rudder;
data[3] = rudder >> 8;
data[4] = xAxisRotation;
data[5] = xAxisRotation >> 8;
data[6] = yAxisRotation;
data[7] = yAxisRotation >> 8;
// HID().SendReport(Report number, array of values in same order as HID descriptor, length)
HID().SendReport(JOYSTICK_REPORT_ID, data, JOYSTICK_STATE_SIZE);
Joystick_ Joystick;
#endif
I tried increasing the physicals maximum but it didn't seem to do anything so I put a // for now. I also tried to switch it to simulation controls usage page but that made the x and y disappear. I feel like I'm not quite understanding the bit shift or masking correctly for it to read in windows. But then why is my throttle and rudder working with this bit shift? I really would like to learn how to fix this before giving up and just using someone else code files completely again, as i only want 4 axis' and I feel I'm very close to making to work.
