I can't get my Wifly shield to connect to my internet network
Hello, i am working on a project where we created a bin with a Flexi force weight sensor in it and are trying to get the readings from the sensor and send the data to a mysql database using an Arduino uno board and Wifly Shield . But i cant seem to get the wifly shield to connect to the wireless network to even get started.
Find below my Arduino code:
#ifndef __CREDENTIALS_H__
#define __CREDENTIALS_H__
char passphrase[] = "vjz7hmh****"; //password Wi-Fi
char ssid[] = "Ziggo855C2A5"; //name Wi-Fi
#endif
#include <SPI.h>
#include "WiFly.h"
#include <Wire.h>
WiFlyClient client("localhost", 80);
int looped = 1;
float var1 = 19.5;    // caliberation factor
int var2 = A0;  // FlexiForce sensor is connected analog pin A0 of arduino
int var3 = 0;
float vout;
  WiFly.begin();
  if( !WiFly.join( ssid, passphrase ) )
      Serial.println( "Error Connecting to Wireless" );
      while( 1 )
          // Hang on failure.
      Serial.println("Success");
  pinMode(var2, INPUT);
  if(client.connect())
    var3 = analogRead(var2);
    vout = (var3 * 5.0) / 1023.0;
    vout = vout * var1;
    Serial.print("Flexi Force sensor: ");
    Serial.print(vout,3);
    Serial.println("");
    client.print("GET/send_data.php?");
    client.print("weight=");
    client.print(vout);
    client.println( " HTTP/1.1");
    client.println( "Host: localhost" );
    client.println( "Content-Type: application/x-www-form-urlencoded" );
    client.println( "Connection: close" );
    client.println();
    client.println();
    client.stop();
    delay(10000);
Find below my PHP code:
<?php
    // Prepare variables for database connection
    $dbusername = "root";  // enter database username, I used "arduino" in step 2.2
    $dbpassword = "";  // enter database password, I used "arduinotest" in step 2.2
    $server = "localhost"; // IMPORTANT: if you are using XAMPP enter "localhost", but if you have an online website enter its address, ie."www.yourwebsite.com"
	$dbname = "trashbot";
    // Connect to your database
    $conn = new mysqli($server, $dbusername, $dbpassword, $dbname);
	// Check connection
	if ($conn->connect_error) {
		die("Connection failed: " . $conn->connect_error);
	// Prepare the SQL statement
    $sql = "INSERT INTO robot (Weight) VALUES ('".$_GET["weight"]."')";
    // Execute SQL statement
    if ($conn->query($sql) === TRUE)
		echo "New record created successfully";
		echo "Error: " . $sql . "
" . $conn->error;
	$conn->close();
How far does your sketch get? i.e. what do you see coming from serial?
I have not used the wifly library but I rather suspect that the client declaration will need the IP address of the web server, rather than localhost.
