I can't get the code to work plz help
So I am trying to make it when the button presses then is does 321 go and then is starts the stopwatch but every time I try it it never works please help Thx :slight_smile:
#include <LiquidCrystal.h>
LiquidCrystal lcd(5, 6, 7, 8, 9, 10);
const int buttonPin = 13;
int buttonState = 0;
lcd.begin(16, 2);
pinMode(buttonPin, INPUT);
lcd.clear();
; int counter = 0;
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
lcd.println(“3”);
lcd.println(“2”);
lcd.println(“1”);
lcd.println(“Goooooo!”);
counter = counter + 1;
lcd.println(counter);
lcd.clear();
can someone help please
Not a great description of your problem. The code does something. What is the difference between what the code actually does and what you want?
Read the how to use this forum-please read sticky to see how to post code properly and some advice on how to get the most from the forum. Use the autoformat (ctrl-t or Tools, Auto Format) function to indent your code to make more readable.
lcd.clear();
What is up with all those blank lines. That just makes code harder to follow.
MOmountainbiking:
Really? You posted this a whole 10 minutes after asking your original question? You do realize you’re not paying for help here, right? People are providing it for FREE.
How is the input wired ?
Do you have a pulldown resistor in place keeping the input LOW when the button is not pressed or is the input floating at an unknown voltage which could be HIGH or LOW ? If not then consider using
pinMode(buttonPin, INPUT_PULLUP);
to activate the built in pullup resistor and wiring the button so that the input is taken LOW when prsesed. You will also need to test for LOW to detect the button press.
  lcd.println("3");
the lcd libray does not support println(). It does not go to a new line but prints strange characters. Use setCursor() to set the print position.
Here is my take on what I think that you are wanting to do. Note code posted in code tags and formatted for readability.
I wired the button switch to ground and set the logic to LOW for button pressed which is the accepted way to wire a switch (like larryd says).
boolean started = false;
   lcd.begin(16, 2);
   lcd.print("Push to start");
   delay(2000);
   lcd.clear();
int counter = 0; //removed useless ;
   if (buttonState == LOW)  // changed to use active low button (wired to ground).
      lcd.setCursor(0, 0);
      lcd.print("3");
      lcd.print("2");
      lcd.print("1");
      lcd.print("Goooooo!");
      started = true;
   if (started == true)
      lcd.setCursor(0,1); // reset cursor
      lcd.print(counter);
      //lcd.clear(); don't use clear, it is slow
