I can't get the ESP32 microcontroller to simultaneously read an RFID card and display the UID on a TFT screen
The big big problem with that site is that it perpetuates the myth that the logic inputs to the chip are 5V tolerant.
From the site:-
However when you look at the data sheet there is absoloutly nothing that supports this. In fact the exact opposite is true. From the data sheet:-
You can clearly see that no such claim is made. The golden rule in electronics is that if it doesn't say something in the data sheet it is NOT true.
True, but here both the display and the RFID reader are being interfaced by using I2C, and this "homework", or required project from @joaoss_19 states the interface to the reader should be SIP.
The Reference Sheet shows only the supply voltages. It is not showing the VIH and VIH which are obviously typical 3.3V.
The ESP8266 MCU is a 3.3V device; however, practically, its logic pins are 5V tolerant -- a fact that 5V devices like UNO works well with ESP8266 wthout any level shifter.
Anyway, it is always wise to comply with data sheets.
The circuit and sketch I showed do use SPI. I2C is not a supplied option with either breakout.
Hello, so I am in the same position as the original poster. Using an ESP32, MFCR522, and TFT screen I am unable to have both external peripherals working together. The screen will also display the appropriate data but the card reader never registers that a card has been presented. The inital build was the card reader and an I2C screen and functioned without issues. When upgrading the setup to a 2.8" tft I am unable to resolve what the issue could be.
I found this post and a few other random ones across google but have yet to find a resolution. I have tried your wiring from above and verfied contents of my code against yours but will only get a white screen.
I have another setup with similar code that is running an I2C screen and the RFId reader works just fine. Only when I change it to use the tft screen does the reader stop working
//Version 2
//Includes base prorgam, includes OTA
#include <SPI.h>
//#include <Adafruit_GFX.h>
#include <Adafruit_ILI9341.h>
#include <HTTPClient.h>
#include <WiFi.h>
#include <soc/soc.h>
#include <soc/rtc_cntl_reg.h>
#include <MFRC522.h>
#include <time.h>
#include <WiFiClient.h>
#include <WebServer.h>
#include <ESPmDNS.h>
#include <Update.h>
//Define the pins used for the RFID reader and setup RFID for use
#define SS_PIN 5
#define RST_PIN 0
//Initialize the RFID Card reader
MFRC522 rfid(SS_PIN, RST_PIN); // Instance of the class
MFRC522::MIFARE_Key key;
// Define pins for TFT display
#define TFT_CS 13
#define TFT_RST 26
#define TFT_DC 12
//#define TFT_SCK 18
//#define TFT_MOSI 23
//#define TFT_MISO 19
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST);
//Software Verstion
String ver = "2.0";
// Init array that will store UID
//how many digits of the card should be recorded
int card_digits = 4;
//byte to store the card info into, this should match the number in card_digits
byte uid[4];
int card_counter = 0;
//Define the location device is installed on
const char* location = "Testerv3";
String employee_name = "";
String old_employee_name= "";
String employee_name2 = "";
String old_old_employee_name = "";
//Define the shift hours based on START Time of each shift, as hour only, 24hr clock
int First_Shift = 0;
int Second_Shift = 0;
int Third_Shift = 0;
//input the length in hours of each shift, ie 10 is a ten hour shift
int shift_length = 10;
//input the time of starting first shift each day, ie 6am is 6
int shift_start = 6;
const char* current_shift;
const char* old_current_shift;
//Setup wifi information
const char* ssid = "CEDIRF";
const char* password = "T3cn0l0g14Rf";
const char* serverName = "http://10.96.8.64/post-esp-data.php";
String apiKeyValue  = "tPmAT5Ab3j7F9";
const char* host = "ESP32";
//timers for checking wifi status
unsigned long previousMillis = 0; //millis for checking inernet
unsigned long previousMillis2 = 0; //millis for sending data
//Timers for sending data to php server
unsigned long interval = 30000; //check for internet connection every 30 seconds
int reporting_minutes_interval = 60; //interval to send the data to server
long reporting_minutes = 0; //minutes counter to send report
long reporting_seconds = 0;
long reporting_milli_seconds = 0;
long time_to_report = 0;
long old_time_to_report = 0;
//Timers for up time minutes
long uptime_minutes = 0;
long uptime_seconds = 0;
long uptime_seconds_counter = 0;
float uptime = 0;
long old_uptime_minutes = 0;
long old_uptime_seconds = 0;
//Timers for downtime minutes
long downtime_minutes = 0;
long downtime_seconds = 0;
long downtime_seconds_counter = 0;
float downtime = 0;
long old_downtime_minutes = 0;
long old_downtime_seconds = 0;
//Receive the response code from the server, if it is 200 then the data was received
int httpResponseCode = 0;
//counter for registering the number of stops
int stop_counter = 0;
int stop_counter_assistant = 0;
int old_stop_counter = 0;
//used to calculate availability of the machine
float availability = 0;
float old_availability = 0;
//used to calculate the number of stops per minute
float stops_minute = 0;
//setup NTP time server and information
const char* ntpServer = "pool.ntp.org";
const long  gmtOffset_sec = -21600;
const int   daylightOffset_sec = 3600;
char timeHour[3];
struct tm timeinfo;
//variables for graph
int hour1 = 0;
int hour2 = 0;
int hour3 = 0;
int hour4 = 0;
int hour5 = 0;
int hour6 = 0;
float hour1_perf = 0;
float hour2_perf = 0;
float hour3_perf = 0;
float hour4_perf = 0;
float hour5_perf = 0;
float hour6_perf = 0;
WebServer server(80);
/* Style */
String style =
"<style>#file-input,input{width:100%;height:44px;border-radius:4px;margin:10px auto;font-size:15px}"
"input{background:#f1f1f1;border:0;padding:0 15px}body{background:#3498db;font-family:sans-serif;font-size:14px;color:#777}"
"#file-input{padding:0;border:1px solid #ddd;line-height:44px;text-align:left;display:block;cursor:pointer}"
"#bar,#prgbar{background-color:#f1f1f1;border-radius:10px}#bar{background-color:#3498db;width:0%;height:10px}"
"form{background:#fff;max-width:258px;margin:75px auto;padding:30px;border-radius:5px;text-align:center}"
".btn{background:#3498db;color:#fff;cursor:pointer}</style>";
/* Login page */
String loginIndex =
"<form name=loginForm>"
"<h1>ESP32 Login</h1>"
"<input name=userid placeholder='User ID'> "
"<input name=pwd placeholder=Password type=Password> "
"<input type=submit onclick=check(this.form) class=btn value=Login></form>"
"<script>"
"function check(form) {"
"if(form.userid.value=='admin' && form.pwd.value=='admin')"
"{window.open('/serverIndex')}"
"else"
"{alert('Error Password or Username')}"
"</script>" + style;
/* Server Index Page */
String serverIndex =
"<script src='https://ajax.googleapis.com/ajax/libs/jquery/3.2.1/jquery.min.js'></script>"
"<form method='POST' action='#' enctype='multipart/form-data' id='upload_form'>"
"<input type='file' name='update' id='file' onchange='sub(this)' style=display:none>"
"<label id='file-input' for='file'>   Choose file...</label>"
"<input type='submit' class=btn value='Update'>"
"<br><br>"
"<div id='prg'></div>"
"<br><div id='prgbar'><div id='bar'></div></div><br></form>"
"<script>"
"function sub(obj){"
"var fileName = obj.value.split('\\\\');"
"document.getElementById('file-input').innerHTML = '   '+ fileName[fileName.length-1];"
"$('form').submit(function(e){"
"e.preventDefault();"
"var form = $('#upload_form')[0];"
"var data = new FormData(form);"
"$.ajax({"
"url: '/update',"
"type: 'POST',"
"data: data,"
"contentType: false,"
"processData:false,"
"xhr: function() {"
"var xhr = new window.XMLHttpRequest();"
"xhr.upload.addEventListener('progress', function(evt) {"
"if (evt.lengthComputable) {"
"var per = evt.loaded / evt.total;"
"$('#prg').html('progress: ' + Math.round(per*100) + '%');"
"$('#bar').css('width',Math.round(per*100) + '%');"
"}, false);"
"return xhr;"
"success:function(d, s) {"
"console.log('success!') "
"error: function (a, b, c) {"
    WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG,0);
   //Initialize serial and wait for port to open
    delay(1500);
    SPI.begin(); // Init SPI bus
    rfid.PCD_Init(); // Init MFRC522
    for (byte i = 0; i < card_digits; i++)
          key.keyByte[i] = 0xFF;
   //Initialize time
  configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
  // Initialize TFT
  tft.begin();
  tft.setRotation(-1);
  tft.fillScreen(ILI9341_BLACK);
  tft.setCursor(0, 0);
  tft.setTextColor(ILI9341_WHITE);
  tft.setTextSize(2);
  tft.print("Software Version: ");
  tft.println(ver);
  Serial.println("TFT Initialized");
  delay(1500);
   WiFi.begin(ssid, password);
   tft.print("Connecting");
   while(WiFi.status() != WL_CONNECTED)
    tft.print(".");
  tft.println("");
  tft.print("Connected to WiFi network with IP Address:");
  tft.println(WiFi.localIP());
  delay(1500);
  /*use mdns for host name resolution*/
  if (!MDNS.begin(host))
          Serial.println("Error setting up MDNS responder!");
          tft.println("Error setting up DNS");
          while (1)
  tft.println("DNS Server Started");
  delay(1500);
  Serial.println("mDNS responder started");
  /*return index page which is stored in serverIndex */
  server.on("/", HTTP_GET, []() {
    server.sendHeader("Connection", "close");
    server.send(200, "text/html", loginIndex);
  server.on("/serverIndex", HTTP_GET, []() {
    server.send(200, "text/html", serverIndex);
  /*handling uploading firmware file */
  server.on("/update", HTTP_POST, []() {
    server.send(200, "text/plain", (Update.hasError()) ? "FAIL" : "OK");
    ESP.restart();
    HTTPUpload& upload = server.upload();
    if (upload.status == UPLOAD_FILE_START) {
      Serial.printf("Update: %s\n", upload.filename.c_str());
      if (!Update.begin(UPDATE_SIZE_UNKNOWN)) { //start with max available size
        Update.printError(Serial);
    } else if (upload.status == UPLOAD_FILE_WRITE) {
      /* flashing firmware to ESP*/
      if (Update.write(upload.buf, upload.currentSize) != upload.currentSize) {
    } else if (upload.status == UPLOAD_FILE_END) {
      if (Update.end(true)) { //true to set the size to the current progress
        Serial.printf("Update Success: %u\nRebooting...\n", upload.totalSize);
  server.begin();
      server.handleClient();
      delay(1);
      unsigned long currentMillis = millis(); //milli counter for checking wifi
      int volts = analogRead(34); //positive side of voltage sensor to D34
       //Serial.println(timeinfo.tm_hour);
     //Define shifts for a ten hour shift day, which would only have a first and second shift
     if (shift_length == 10)
       First_Shift = shift_start;
       Second_Shift = shift_start + shift_length;
       if ((timeinfo.tm_hour >= First_Shift) && (timeinfo.tm_hour < (First_Shift + shift_length)))
         current_shift = "First";
        if ((timeinfo.tm_hour >= Second_Shift) && (timeinfo.tm_hour < (Second_Shift + shift_length)))
         current_shift = "";
     //Define shifts for a 8 hour shift day, which would only have a first and second shift and third shift
     if (shift_length == 8)
       Third_Shift = shift_start + shift_length + shift_length;
         current_shift = "Second";
         if ((timeinfo.tm_hour >= Third_Shift) && (timeinfo.tm_hour < (Third_Shift + shift_length)))
         current_shift = "Third";
      //check if a new card has been passed in front of the card reader
      if (rfid.PICC_IsNewCardPresent() && rfid.PICC_ReadCardSerial())
                 uid[i] = rfid.uid.uidByte[i];
                 //record the hex number of the card to employee_name
                 employee_name2.concat(String(uid[i], HEX));
            //printHex(rfid.uid.uidByte, rfid.uid.size);
            //Turn the hex digits received from card reader into employee number, make sake sure that the uid[x] is the same number of digits you are looking for on the card
            //employee_name = (String)uid[1] + (String)uid[2] + (String)uid[3] + (String)uid[4];
            Serial.println(employee_name2);
            rfid.PICC_HaltA();
            rfid.PCD_StopCrypto1();
            //check if a new card has been waved in front, if its the same card do nothing
            if (employee_name2 != old_employee_name)
                  card_counter = 1;
                  old_old_employee_name = old_employee_name;
                  old_employee_name = employee_name2;
                  tft.setTextSize(2);
                  tft.setCursor(0,0);
                  tft.println("Card Has");
                  tft.println("Been");
                  tft.println("Scanned");
                  delay(600);
  // if WiFi is down, try reconnecting
  if ((WiFi.status() != WL_CONNECTED) && (currentMillis - previousMillis >=interval))
          tft.setTextSize(1);
          tft.setCursor(0,0);
          tft.print(millis());
          tft.println("Reconnecting to WiFi...");
          WiFi.disconnect();
          WiFi.reconnect();
  //the system will only monior the status of the machine if it is connected to wifi, else it would not have a place to send the data to
  if(WiFi.status()==WL_CONNECTED)
     WiFiClient client;
     HTTPClient http;
     http.begin(client, serverName);
    //Time for monitoring when to send the report, this is not on the hour but every hour since the arduino has started
    if (millis() - reporting_milli_seconds > 1000)
      reporting_seconds ++;
      reporting_milli_seconds = millis();
    if(reporting_seconds == 60)
      reporting_minutes++;
      //Get the hour from the NTP server
      getLocalTime(&timeinfo);
      //Serial.println(hours);
      //setup timeinfo as a data store from the time pulled from NTP server
      //pull the hour from the time on the NTP server
      strftime(timeHour,3, "%H", &timeinfo);
    //Countdownt to when the report will be sent
    time_to_report = reporting_minutes_interval - reporting_minutes;
    //start the counter for up time and downtime minutes based on D34, this is based on if there is an active schedule or not
    if( current_shift != "" )
          //Serial.print("Volts:");
          //Serial.println(volts);
        if (volts == 0) //if voltage is greater than this the machine is running
               if ((millis()-uptime_seconds_counter) > 1000)
                        uptime_seconds++;
                        uptime_seconds_counter = millis();
                        availability = ((float)uptime_minutes / ((float)uptime_minutes + (float)downtime_minutes))*100;
                        //this calculates the stops per minute out of every hour
                        stops_minute = (float)stop_counter / ((float)downtime_minutes + (float)uptime_minutes);
              if (uptime_seconds == 60)
                      uptime_minutes++;
                      uptime_seconds = 0;
         //With the relay, 0 volts is running and positive voltage is down
        if (volts > 0) //if voltage is less than this then start downtime timer
               if ((millis()-downtime_seconds_counter) > 1000)
                       if (stop_counter_assistant == 0)
                       stop_counter++;
                       downtime_seconds++;
                       downtime_seconds_counter = millis();
                       stop_counter_assistant = 1;
              if (downtime_seconds == 60)
                       downtime_minutes++;
    //when the counter hits the reporting interval send the data to php server
    //add the or statement here so if someone swipes their rfid card it will send the report right then
    while (((reporting_minutes == reporting_minutes_interval) || (card_counter == 1)) && current_shift != "")
           if (card_counter = 1)
             employee_name = old_old_employee_name;
               else employee_name = employee_name2;
         //Display status
           tft.setTextSize(1);
           tft.setCursor(0,0);
           tft.println("Sending to Server");
           //send data to php server
           while (httpResponseCode != 200)
               http.addHeader("Content-Type", "application/x-www-form-urlencoded");
               String httpRequestData = "api_key=" + apiKeyValue + "&location=" + location + "&employee_name=" + employee_name + "&current_shift=" + current_shift +"&uptime=" + uptime + "&downtime=" + downtime + "&stop_counter=" + stop_counter + "&stops_minute=" + stops_minute + "&availability=" + availability;
              //String httpRequestData = "api_key=tPmAT5Ab3j7F9&location=L6W1";
              httpResponseCode = http.POST(httpRequestData);
              Serial.println(httpResponseCode);
           if (httpResponseCode = 200)
             //reset all of the couners, timers, etc
             uptime_minutes = 0;
             uptime_seconds = 0;
             stop_counter = 0;
             stop_counter_assistant =0;
             availability = 0;
             stops_minute = 0;
             uptime = 0;
             downtime = 0;
             card_counter = 0;
             delay(300);
              Serial.println("WiFi Disconnected");
  if (current_shift = "")
  //Draw Boxes etc
  tft.fillRect(0,0,320,10,ILI9341_YELLOW);
  tft.drawRect(0,10,315,35,ILI9341_RED);
  tft.drawRect(1,11,315,35,ILI9341_RED);
  tft.drawRect(2,12,315,35,ILI9341_RED);
  tft.drawRect(3,13,315,35,ILI9341_RED);
  tft.drawRect(4,14,315,35,ILI9341_RED);
  //tft.fillRect(120,120,120,120,ILI9341_RED);
 //Registering data to variables to monitor performance, this probably needs to run only when shift is active
    if (hour1 != timeinfo.tm_hour)
             hour1 = timeinfo.tm_hour;
             hour2 = hour1 - 1;
             hour3 = hour2 - 2;
             hour4 = hour3 - 3;
             hour5 = hour4 - 4;
             hour6 = hour5 - 5;
             //hour2_perf = hour1_perf;
             //hour3_perf = hour2_perf;
             //hour4_perf = hour3_perf;
             //hour5_perf = hour4_perf;
             //hour6_perf = hour5_perf;
             //hour1_perf = availability;
               hour2_perf = 90;
               hour3_perf = 72;
               hour4_perf = 40;
               hour5_perf = 60;
               hour6_perf = 85;
    //barss for the Hour 2
    if (hour2_perf != 0 )
          if(hour2_perf>=90)
                tft.fillRect(20,170,30,60,ILI9341_GREEN);
                tft.setCursor(20,232);
                tft.fillRect(20,232,10,5,ILI9341_BLACK);
                tft.print(hour2);
                tft.print(":00");
          if((hour2_perf >=70) && (hour2_perf<90))
                tft.fillRect(20,190, 30,40,ILI9341_YELLOW);
                tft.print(hour2);
                tft.print(":00");
          if(hour2_perf < 70)
                tft.fillRect(20,210,30,20,ILI9341_RED);
                tft.print(hour2);
                tft.print(":00");
    //bars for hour 3
    if (hour3_perf != 0 )
          if(hour3_perf>=90)
                tft.fillRect(70,170,30,60,ILI9341_GREEN);
                tft.setCursor(70,232);
                tft.print(hour2);
                tft.print(":00");
          if((hour3_perf >=70) && (hour3_perf<90))
                tft.fillRect(70,190, 30,40,ILI9341_YELLOW);
                tft.print(hour3);
                tft.print(":00");
          if(hour3_perf < 70)
                tft.fillRect(70,210,30,20,ILI9341_RED);
                tft.print(hour2);
                tft.print(":00");
  //clearing the RSSI from the screen
  tft.fillRect(175,1,20,8,ILI9341_YELLOW);
    //Display the performance of the operator in different colors based on their results
    if (availability >= 90)
        if (old_availability != availability)
             tft.fillRect(0,100,320,62, ILI9341_GREEN);
             tft.setCursor(40,105);
             tft.setTextColor(ILI9341_BLACK);
             tft.setTextSize(3);
             tft.print("Performance: ");
             tft.setCursor(105,138);
             tft.print(availability, 1);
             tft.print("%");
             //tft.fillRect(171,223,75,14,ILI9341_GREEN);
              old_availability = availability;
    if (availability < 90)
             tft.fillRect(0,100,320,62, ILI9341_RED);
             tft.setTextSize(3);
             tft.print("%");
             //tft.fillRect(171,223,75,14,ILI9341_RED);
  //display IP Address in top Row
  tft.setTextSize(1);
  tft.setCursor(0,2);
  tft.print("IP: ");
  //display RSSI in top Row
  tft.setCursor(100,2);
  tft.print("Network RSSI:");
  tft.setCursor(178,2);
  tft.println(WiFi.RSSI());
  //display Software version in top row
  tft.setCursor(210,2);
  tft.print("Software: ");
  tft.print(ver);
  //Clear the Time to Report number
    if (old_time_to_report != time_to_report)
          tft.fillRect(79,16,17,8,ILI9341_BLACK);
          old_time_to_report = time_to_report;
  tft.setCursor(6,17),
  tft.print("Min to Up/L: ");
  tft.print(time_to_report);
//Clear the text in the shift spot
    if (old_current_shift != current_shift)
           tft.fillRect(41,26,53,12,ILI9341_BLACK);
           old_current_shift = current_shift;
  tft.setCursor(6,30);
  tft.print("Shift: ");
  tft.print(current_shift);
//Clear the minutes in uptime
  //if (old_uptime_minutes != uptime_minutes)
        //   tft.fillRect(190,56,27,18,ILI9341_RED);
        //   old_uptime_minutes = uptime_minutes;
  //Clear the seconds in uptime
  if (old_uptime_seconds != uptime_seconds)
           tft.fillRect(190,56,80,20,ILI9341_YELLOW);
           old_uptime_seconds = uptime_seconds;
  tft.setCursor(20,60);
  tft.setTextSize(2);
  tft.print("Uptime Min/Hr: ");
  tft.print(uptime_minutes);
  tft.print(":");
  tft.println(uptime_seconds);
    //Clear the minutes in downtime
  //if (old_downtime_minutes != downtime_minutes)
          //tft.fillRect(198,76,30,22,ILI9341_BLUE);
         // old_downtime_minutes = downtime_minutes;
  //Clear the seconds in the downtime
  if (old_downtime_seconds != downtime_seconds)
          tft.fillRect(198,76,80,20,ILI9341_YELLOW);
          old_downtime_seconds = downtime_seconds;
  tft.setCursor(20,80);
  tft.print("Dwntime Min/Hr: ");
  tft.print(downtime_minutes);
  tft.print(":");
  tft.println(downtime_seconds);
  //Clear and post data for number of stops
  if (old_stop_counter != stop_counter)
         tft.fillRect(188,16,27,10,ILI9341_BLUE);
         tft.setTextSize(1);
         tft.setCursor(120,17);
         tft.print("# of Stops: ");
         tft.println(stop_counter);
   tft.setTextSize(1);
   tft.setCursor(120,24);
   tft.print("Emploee: ");
   tft.print(employee_name2);
  //tft.print("Stops/Hr: ");
  //tft.println(stops_minute);
  //tft.print("Shift: ");
  //tft.println(current_shift);
  //tft.print("User:");
  //tft.println(employee_name2);
  //tft.setTextColor(ILI9341_BLACK);
  //tft.setCursor(178,0);
  //tft.println(WiFi.RSSI());
  downtime =downtime_minutes+((float)downtime_seconds / 100);
  uptime = uptime_minutes + ((float)uptime_seconds / 100);
  //Serial.print("Downtime: ");
  //Serial.println(downtime);
  //Serial.print("Uptime: ");
  //Serial.println(uptime);
  void printHex(byte *buffer, byte bufferSize)
         for (byte i = 0; i < bufferSize; i++)
               Serial.print(buffer[i] < 0x10 ? " 0" : " ");
               Serial.print(buffer[i], HEX);
Nevermind, my MISO wire for RFID was one slot off on the breadboard.
This schematic works
Great!
Well done for tracking this down.
Hi, im having the exact same problem. im on esp32 wroom 32d . any one got works? i got a Rfid and tft 3.5 with: GND-VCC-SCL-SDA-RST-DC-CS-BL PINS all conected and working, this is my test code: // Pines para la pantalla TFT
#define TFT_CS 15 // Chip Select
#define TFT_DC 4 // Data/Command
#define TFT_RST 2 // Reset
#define TFT_SCK 18 // SPI Clock
#define TFT_MOSI 23 // SPI Data Out
// Pines para el lector RFID
#define RFID_SDA 5 // Chip Select (CS)
#define RFID_RST 21 // Reset
#define RFID_SCK 14 // SPI Clock
#define RFID_MOSI 13 // SPI Data Out
#define RFID_MISO 19 // SPI Data In
