i can't get the timer to work in the lcd shield sub menu
i can’t get the timer to work in the lcd shield sub menu
void menuItem1() { // Function executes when you select the 2nd item from main menu
int activeButton = 0;
int S = 59; // count seconds
int M = 59; // count minutes
int H = 11; // count hours
lcd.clear();
lcd.setCursor(0, 1);
drawInstructions();
lcd.setCursor(0, 0);
lcd.print(“NEXT FEED”);
lcd.setCursor(6, 1);
lcd.print(":");
lcd.setCursor(9, 1);
lcd.print(":");
S–;
if(S<0)
M–;
S=59;
if(M<0)
H–;
M=59;
if(H<0)
H=23;
M=59;
S=59;
if(M>9)
lcd.setCursor(7,1);
lcd.print(M);
lcd.setCursor(7,1);
lcd.print(“0”);
lcd.setCursor(8,1);
lcd.print(M);
lcd.setCursor(9,1);
lcd.print(":");
if(S>9)
lcd.setCursor(10,1);
lcd.print(S);
lcd.print(“0”);
lcd.setCursor(11,1);
lcd.print(S);
lcd.setCursor(12,1);
lcd.print(" ");
if(H>9)
lcd.setCursor(4,1);
lcd.print (H);
lcd.setCursor(4,1);
lcd.print(“0”);
lcd.setCursor(5,1);
lcd.print(H);
lcd.setCursor(6,1);
lcd.print(":");
Your code doesn't compile.
Please remember to use code tags when posting code.
#include <LiquidCrystal.h>
//initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8, 9, 4, 5, 6, 7); // pins connected to LCD
lcd.begin(16,2);//set up the LCD’s number of columns and rows
lcd.setCursor(1,0);
lcd.print (“Next Feed In”);
lcd.setCursor(6,1);
lcd.print(":");
lcd.setCursor(9,1);
lcd.print(":");
S–;
if(S<0)
M–;
S=59;
if(M<0)
H–;
M=59;
if(H<0)
H=23;
M=59;
S=59;
if(M>9)
lcd.setCursor(7,1);
lcd.print(M);
lcd.setCursor(7,1);
lcd.print(“0”);
lcd.setCursor(8,1);
lcd.print(M);
lcd.setCursor(9,1);
lcd.print(":");
if(S>9)
lcd.print(S);
lcd.print(“0”);
lcd.print(S);
lcd.print(" ");
if(H>9)
lcd.setCursor(4,1);
lcd.print (H);
lcd.setCursor(4,1);
lcd.print(“0”);
lcd.setCursor(5,1);
lcd.print(H);
lcd.setCursor(6,1);
lcd.print(":");
F521I0MIPET1CCA.ino (14 KB)
The code in your attachment is completely different from the code in your Post. And the code in your Post is almost unreadable.
I don’t understand what you want to do.
To make it easy for people to help you please modify your post and use the code button </> so your code looks like this and is easy to copy to a text editor. See How to use the Forum
Also please use the AutoFormat tool to indent your code for easier reading.
…R
And please don't waste our time (and yours) by double posting
...R
