I can't manage to upload my code to my Ardino Uno!
You should see something like this during uploading:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
     Using Port                    : COM4
I mean the port, on Windows it's COM on linux and MacOS it's dev/...
I can see you have selected some Bluetooth device as your com:
     System wide configuration file is "/Users/leoabbott/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
     User configuration file is "/Users/leoabbott/.avrduderc"
     User configuration file does not exist or is not a regular file, skipping
     Using Port                    : /dev/cu.Bluetooth-Incoming-Port
Yes. Your errors are all in these lines:
void loop() { // You should not have a '}' here.
  int switchState = digitalRead(2);
//^ You forgot to declare switchState by specifying a type.  You tried to use an undeclared variable.
  if (switchState == LOW) { // You should not have a '}' here.
A handy tool for seeing if the problem is you code or the upload process is available in the IDE.
Next to the “upload” button at the upper left corner is a “verify” button.
If the code doesn’t verify, fix it, uploading it will fail.
Until you can read through the errors and instantly see which is your problem. That is to say, I still verify quite often as I tinker, always trying to maintain code that complies or just to catch things ahead of time like failing to declare a variable or like that, missing semicolons, unclosed quotes &c.
a7
