I can't open file on micro sd card
Use arduino with Linksprite JPEG Camera . i want save image to micro sd card but open file jpg. :sweat_smile:
#include <SoftwareSerial.h>
#include <SD.h>
byte incomingbyte;
SoftwareSerial mySerial(2,3);                     //Configure pin 4 and 5 as soft serial port
int a=0x0000,j=0,k=0,count=0,i=0,p=0;                    //Read Starting address
uint8_t MH = 0x00,ML = 0x00;
boolean EndFlag=0,HeaderFlag=0;
int chipSelect = 4;
File logfile;
void SendResetCmd();
void SetBaudRateCmd();
void SetImageSizeCmd();
void SendTakePhotoCmd();
void SendReadDataCmd();
void StopTakePhotoCmd();
  Serial.begin(38400);
  mySerial.begin(38400);
  a-=0x20;
  //see if the card is present and can be initialized
  if (!SD.begin(chipSelect)) {
    Serial.print("Card failed, or not present");
    return;
  Serial.println("card initialized.");
 // create a new file
  char filename[] = "Test10.jpg";
  for (uint8_t i = 0; i < 100; i++) {
    filename[4] = i/10 + '0';
    filename[5] = i%10 + '0';
    if (! SD.exists(filename)) {
      // only open a new file if it doesn't exist
      logfile = SD.open(filename, FILE_WRITE);
      break;  // leave the loop!
  Serial.print("Logging to: ");
  Serial.println(filename);
     Serial.println("about to take picture...");
     byte a[32];
     p=0;
     SendResetCmd();
     delay(4000);                               //After reset, wait 2-3 second to send take picture command
     SendTakePhotoCmd();
     while(mySerial.available()>0)
        incomingbyte=mySerial.read();
      while(!EndFlag)
         j=0;
         k=0;
         count=0;
         SendReadDataCmd();
         delay(20);
               k++;
               if((k>5)&&(j<32)&&(!EndFlag))
               a[j]=incomingbyte;
               if((a[j-1]==0xFF)&&(a[j]==0xD9))      //Check if the picture is over
               EndFlag=1;
               j++;
          count++;
          for(j=0;j<count;j++)
          {   if(a[j]<0x10)
              Serial.print("0");
              Serial.print(a[j], HEX);
              Serial.print(" ");
          }           //Send jpeg picture over the serial port
          if(((a[j-32]==0xFF)&&(a[j-31]==0xD8))||(p))
            logfile.print((char*)a);
            p=1;
     logfile.close();
     Serial.print("Finished writing data to file");
     while(1);
//Camera functions
//Send Reset command
void SendResetCmd()
      mySerial.write(0x56);
      mySerial.write((byte)0x0);
      mySerial.write(0x26);
      mySerial.write(0x31);
      mySerial.write(0x05);
      mySerial.write(0x04);
      mySerial.write(0x01);
      mySerial.write(0x19);
      mySerial.write(0x22);
      mySerial.write(0x24);
      mySerial.write(0x03);
      mySerial.write(0xAE);
      mySerial.write(0xC8);
//Send take picture command
      mySerial.write(0x36);
//Read data
      MH=a/0x100;
      ML=a%0x100;
      mySerial.write(0x32);
      mySerial.write(0x0c);
      mySerial.write(0x0a);
      mySerial.write(MH);
      mySerial.write(ML);
      mySerial.write(0x20);
      a+=0x20;                            //address increases 32£¬set according to buffer size
The problem isn't that you can't open the file. The problem is that the file contains data that does NOT represent a JPEG file. So, your post title is wrong.
Is 4000 2 or 3 seconds? Stupid comments need to at least be right.
I guess it doesn't matter that the camera might have told you to go take a flying leap.
         SendReadDataCmd();
         delay(20);
The Arduino can read data far faster than it can arrive. This is completely the wrong approach to getting picture data from the camera. There is some end-of-packet marker that indicates that the end of the picture data has arrived. You need to keep reading data, and waiting as necessary, until that marker arrives.
Isyourspacekeybroken? If so, get it fixed. If not, use it!
Not even in the same universe as the correct way to write binary data to the SD card.
Cross-posting won't make you any friends here, so I've deleted the duplicate.
