I can't porting this scheck from MKR1000 to Mkr1010
define BLYNK_PRINT Serial    // Comment this out to disable prints and save space
#include <SPI.h>
#include <WiFi101.h>
#include <BlynkSimpleMKR1000.h>
#include <Wire.h>
#include <SimpleTimer.h>
#include <FlashAsEEPROM.h>
#include "DHT.h"
#include <BlynkSimpleWiFiShield101.h>
#define DHTPIN 1    // what pin we're connected to, pin1 is 5th pin from end
#define analogPin A5//sensore suolo
#define analogPin A6//sensore temperatura terreno
#define beta 3950 //the beta of the thermistor
#define resistance 10 //the value of the pull-up resistor
#include <Wire.h>
int sm=0;
int pinMoist=A5;
// connessione display (pin)
const int soilTemperature = A6;
const int soilMoisture = A5;
const int tsu = 4;
const int tgiu = 5;
const int hsu = 8;
const int hgiu = 2;
const int ssu = 13;
const int sgiu = 14;
//serpentina riscaldamento
const int vout =6;
const int v2out =3;
const int tout =7;
//umidificatore
const int hout =9;
//irrigazione pompa
const int sout =10;
//dichiarazione pulsanti
int statotsu =0;
int statotgiu =0;
int statohsu =0;
int statohgiu =0;
int tempimpostata =0;
int umidimpostata =0;
int soil = 750;
//umidità terreno
//int umtrimpostata =0;
// Set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x27, 16, 2);
const int riscaldamento =7;
const int irrigazione = 10;
const int umidificatore =9;
const int ventilazione =6;
//const int stato = irrigazione ;
//#define DHTTYPE DHT21  // DHT 21
#define DHTTYPE DHT22  // DHT 22
//Adafruit_BMP085 bmp;
DHT dht(DHTPIN,DHTTYPE);
SimpleTimer timer;
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "23b0f2756b2e4bcc83d91908426df871";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "Alice-63479497"; //  your network SSID (name)
char pass[] = "a28f1gldje7lmwe88sb0vzzn";    //your network password
int keyIndex = 0;     // your network key Index number (needed only for WEP)
//int relayPin = 6;
void sendSensor()
 float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
  long a =1023 - analogRead(A6); //read thermistor value
  float tempC = beta /(log((1025.0 * 10 / a - 10) / 10) + beta / 298.0) - 273.0;
  float t2 =tempC;
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)|| isnan(sm) )
    Serial.println("Failed to read from DHT sensor!");
    return;
  // Compute heat index in Fahrenheit (the default)
  float hif = dht.computeHeatIndex(f, h);
  // Compute heat index in Celsius (isFahreheit = false)
  float hic = dht.computeHeatIndex(t, h, false);
  Blynk.virtualWrite(V2, h);
  Blynk.virtualWrite(V3, t);
  Blynk.virtualWrite(V5, pinMoist );
  //Serial.println(soilMoisture);
  Blynk.virtualWrite(V6, t2 );
  //Serial.println(soilTemperature);
  Blynk.virtualWrite(V7, soil );
  Blynk.virtualWrite(V8, tempimpostata );
  Blynk.virtualWrite(V9, umidimpostata );
// This function will be called every time Slider Widget
// in Blynk app writes values to the Virtual Pin 1
//BLYNK_WRITE(V1) {
//  int pinValue = param.asInt(); // assigning incoming value from pin V1 to a variable
  // You can also use:
  // String i = param.asStr();
  // double d = param.asDouble();
  //SerialUSB.print("V1 button is: ");
 // SerialUSB.println(pinValue);
  //if (pinValue == 1) {
    //digitalWrite(relayPin, HIGH);
 // } else {
 //   digitalWrite(relayPin, LOW);
  lcd.begin();
  lcd.backlight();
lcd.setCursor(0,0);
lcd.print("T:");
lcd.setCursor(4,0);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print("H:");
lcd.setCursor(4,1);
lcd.print(" ");
lcd.setCursor(8,0);
lcd.print(" Soil:");
//riscaldamento-ventoole
pinMode(tout, OUTPUT);
 pinMode(vout, OUTPUT);
 //umidificatore-ventole
 pinMode(hout, OUTPUT);
 //irrigazione
 pinMode(sout, OUTPUT);
// If the EEPROM is empty then isValid() is false
  if (!EEPROM.isValid()) {
    Serial.println("EEPROM is empty, writing some example data:");
    Serial.print("->");
    for (int i=0; i<20; i++) {
      EEPROM.write(i, 100+i);
      Serial.print(" ");
      Serial.print(100+i);
    EEPROM.commit();
    Serial.println("Done!");
    Serial.print("After commit, calling isValid() returns ");
    Serial.println(EEPROM.isValid());
    Serial.println("EEPROM has been written.");
    Serial.println("Here is the content of the first 20 bytes:");
    Serial.print("->");
      Serial.print(" ");
      Serial.print(EEPROM.read(i));
  Blynk.begin(auth, ssid, pass);
  // Or specify server using one of those commands:
  //Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 8442);
  //Blynk.begin(auth, ssid, pass, server_ip, port);
   dht.begin();
   Wire.begin(); // required by BMP180
 //   bmp.begin();
    timer.setInterval(1000L, sendSensor);
pinMode(riscaldamento, OUTPUT);
  delay(5000);
BLYNK_CONNECTED() {
Blynk.syncVirtual(V20);
// when App writes value to Virtual Pin 1
BLYNK_WRITE(V20)
 if(param.asInt()==1)
     digitalWrite(riscaldamento, LOW);
     digitalWrite(riscaldamento, HIGH);
     pinMode(2, OUTPUT);
sm = analogRead(pinMoist);
  Serial.print("Raw reading ");
  Serial.println(a);
  //the calculating formula of temperature
statotsu = digitalRead (tsu);
if( statotsu == HIGH)
{tempimpostata++;}
statotgiu = digitalRead (tgiu);
if( statotgiu == HIGH)
{tempimpostata--;}
statohsu = digitalRead (hsu);
if( statohsu == HIGH)
{umidimpostata++;}
statohgiu = digitalRead (hgiu);
if( statohgiu == HIGH)
{umidimpostata--;}
statohsu = digitalRead (ssu);
{soil++;}
statohgiu = digitalRead (sgiu);
{soil--;}
    int t = dht.readTemperature();
    delay(100);
    lcd.setCursor(2, 0);
    lcd.print(t);
    lcd.setCursor(6, 0);
lcd.print(tempimpostata);
    int h = dht.readHumidity();
    delay(100);
    lcd.setCursor(2, 1);
    lcd.print(h);
    lcd.setCursor(6, 1);
lcd.print(umidimpostata);
    lcd.setCursor(9, 1);
lcd.println( soil);
if (tempimpostata > -1 && tempimpostata < 10)
{ lcd.setCursor (7, 0);
lcd.print ("  ");}
if (umidimpostata > -1 && umidimpostata < 10)
{ lcd.setCursor (7, 1);
lcd.print ("  ");}
if (soil > -1 && soil < 10)
lcd.print (" ");}
delay(100);
if ( t < tempimpostata  )
{digitalWrite (tout, HIGH );}
else {digitalWrite (tout, LOW);}
delay(100);
if ( soil > sm )
{digitalWrite ( sout, HIGH );}
else {digitalWrite (sout, LOW);}
delay(100);
if ( umidimpostata < h && t > tempimpostata ) {
digitalWrite ( vout, HIGH );
digitalWrite (vout, LOW);
delay(100);
if ( h < umidimpostata )
{digitalWrite ( hout, HIGH );}
else {digitalWrite (hout, LOW);
delay(100);
timer.run(); // Initiates SimpleTimer
  Blynk.run();
delay (150);
this is the error:
Arduino:1.6.9 (Windows 10), Scheda:"Arduino/MKR1010"
The mkrwifi1010 board (samd platform, arduino package) is unknown
Error during compilation for the Arduino MKR WiFi 1010 card.
Found invalid library in C:\Program Files (x86)\Arduino\libraries\PietteTech_DHT-master: C:\Program Files (x86)\Arduino\libraries\PietteTech_DHT-master
Trovata libreria non valida in C:\Program Files (x86)\Arduino\libraries\u8glib-master: C:\Program Files (x86)\Arduino\libraries\u8glib-master
Found invalid library in C:\Program Files (x86)\Arduino\libraries\u8glib-master: C:\Program Files (x86)\Arduino\libraries\u8glib-master
Here's the important part of the output:
This error is not caused by your code.
The "Board ... is unknown" error occurs when a Boards Manager installation of a different version of a hardware package fails to completely uninstall the previous version. Here's how you solve it:
  • Click the link on the line following File > Preferences > More preferences can be edited directly in the file. This will open the Arduino15 (or similar name depending on OS) folder.
  • Navigate to the packages/arduino/hardware/samd folder.
  • You will see two folders. One is named by the version of the package you currently have installed, the other is named by the version of the package you previously had installed. Delete the folder with the previous version name. Please be very careful when deleting things on your computer. When in doubt back up!
These warnings are unrelated to the compilation failure:
As long as you don't need those libraries, the invalid libraries won't cause any problems. However, it is annoying to see these warnings on every compilation. If you want to fix the invalid library warnings, you only need to delete the folders C:\Program Files (x86)\Arduino\libraries\PietteTech_DHT-master and C:\Program Files (x86)\Arduino\libraries\u8glib-master.
In the case of u8glib, the problem is that you didn't install the Arduino library version of that project. You can find it here:
  • GitHub - olikraus/U8glib_Arduino: U8glib library for Arduino
  • You can also install it via Library Manager:
  • Sketch > Include Library > Manage Libraries...
  • Wait for download to finish.
  • In the "Filter your search" field, type "u8glib"
  • Scroll down through the results until you see "U8glib by oliver" click on it.
  • Click "Install".
  • Wait for installation to finish.
  • Click "Close".
In the case of PietteTech_DHT, that is a Particle library, not an Arduino library. Although it is easy enough to write Particle libraries that are also compatible with Arduino, the Particle community seem to not put any value in that. In fact, they often intentionally break Arduino compatibility when they "port" Arduino libraries to Particle. If you really need this library, you should be able to make some minor changes to make it Arduino compatible. This will serve as a guide to fixing the library structure:
You also need to change this line in PietteTech_DHT.h:
#include "application.h"
to:
#ifdef ARDUINO
#include <Arduino.h>
#else
#endif
However, there are some excellent DHT Arduino libraries so it's likely that it's easier just to use one of those libraries instead of fixing the PietteTech_DHT library
