I can't print values correctly in lcd, but, in serial it are good
Hey, I am new with arduino, I am having difficulty to print in a 16x2 LCD the variable percent, in serial it’s ok. Someone can explain it?
my code…:
/* use info from
#include <LiquidCrystal_I2C.h> // inclui biblioteca para comunicação I2C
#include<Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2); //Coloca o display no endereço I2c 0x27, tipo 16x2
/* Constantes LCD */
const int LCD_NB_ROWS = 2;
const int LCD_NB_COLUMNS = 16;
/* Caracteres personalizados */
byte DIV_0_OF_5[8] = {
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000
}; // 0 / 5
byte DIV_1_OF_5[8] = {
B10000,
B10000,
B10000,
B10000,
B10000,
B10000,
B10000,
B10000
}; // 1 / 5
byte DIV_2_OF_5[8] = {
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000
}; // 2 / 5
byte DIV_3_OF_5[8] = {
B11100,
B11100,
B11100,
B11100,
B11100,
B11100,
B11100,
B11100
}; // 3 / 5
byte DIV_4_OF_5[8] = {
B11110,
B11110,
B11110,
B11110,
B11110,
B11110,
B11110,
B11110
}; // 4 / 5
byte DIV_5_OF_5[8] = {
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111
}; // 5 / 5
  • Função de configuraçao barra de progressão.
  • Utilisa caracteres personalisados de 0 à 5 (6 et 7 disponiveis).
    void setup(){
lcd.init();
lcd.backlight();
setup_progressbar();
lcd.clear();
delay(2000);
void setup_progressbar() {
/*salva caracteres na memoria do LCD */
lcd.createChar(0, DIV_0_OF_5);
lcd.createChar(1, DIV_1_OF_5);
lcd.createChar(2, DIV_2_OF_5);
lcd.createChar(3, DIV_3_OF_5);
lcd.createChar(4, DIV_4_OF_5);
lcd.createChar(5, DIV_5_OF_5);
  • Função desenhando a barra de progresso.
  • porcentagem a exibir.
    void draw_progressbar(byte percent) {
/* Exibe o novo valor numericamente na primeira linha*/
lcd.setCursor(0, 0);
// if (percent < 100) lcd.print(" “);
// if (percent < 10) lcd.print(” ");
lcd.print(percent); // HERE IS THE PROBLEM, the percent only appears from 0 to 1% on display
Serial.print (percent);
lcd.print("% ");
// N.B. Os dois espaços no final da linha permitem excluir os valores da porcentagem
//anterior quando você muda de um valor de dois ou três dígitos para um valor de dois ou um número.
/* Mova o cursor para a segunda linha */
lcd.setCursor(0, 1);
/* Mapeie o intervalo (0 ~ 100) para o intervalo (0 ~ LCD_NB_COLUMNS * 5) */
byte nb_columns = map(percent, 0, 100, 0,80);
/* Desenhe cada caractere pessoal da linha */
for (byte i = 0; i < LCD_NB_COLUMNS; ++i) {
/* Dependendo do número de colunas restantes para exibir*/
if (nb_columns == 0) { // Caixa vazia
lcd.write((byte) 0);
} else if (nb_columns >= 5) { //Caso cheio
lcd.write(5);
nb_columns -= 5;
} else { // Última caixa não vazia
lcd.write(nb_columns);
nb_columns = 0;
void loop(){
/*Valor percentual da barra de progresso */
static byte percent;
/* mostra o valor */
draw_progressbar(percent);
/* incrementa a porcentagem */
if (++percent == 101) {
// Retorna para zero se a porcentagem exceder 100%
percent = 0;
/* Petit temps d’attente */
delay(250);
I don't know what exactly your problem is but try to exchange the line
lcd.print(percent);
by
lcd.print((int)percent);
Do you mean the " % " character?
