I can't receive Telegram notifications on Phone
Hello,
Within the scope of smart home automation, I use the "Bots" of the Telegram application to notify my mobile phone of any door status via wifi.
type or paste code here
in Arduino program
1- When wifi connection is provided, a one-time "Bot started up" message is sent in VOID Setup.
2- As the door status changes in the loop, a status message is sent as "open" or "closed".
Problem is: I can't receive status change messages on my phone even though the first message came to my phone just fine.
Everything is normal in the serial port, the program flow goes through all the Loop commands. But
The "Bot.Sendmessage" command is dysfunctional or the phone is not detected.
Any help with the solution would be greatly appreciated.
Arduino Sketch excerpt
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include <UniversalTelegramBot.h>
#include <ArduinoJson.h>
// Set GPIOs for LED and reedswitch
const int reedSwitch = 4;
const int led = 2; //optional
// Detects whenever the door changed state
bool changeState = false;
// Holds reedswitch state (1=opened, 0=close)
bool state;
String doorState;
// Auxiliary variables (it will only detect changes that are 1500 milliseconds apart)
unsigned long previousMillis = 0;
const long interval = 1500;
const char* ssid = "Kitap";
const char* password = "12345678";
// Initialize Telegram BOT   your Bot Token (Get from Botfather)
#define BOTtoken "5026400662:AAF1zr5OXMKaT1yXfFp_pykt3YN43zmYc0w" // evimBot
//#define BOTtoken "5035250269:AAHBg-L73AGHBMJLC-H_X6wDJiBvBGSSLNk"   // evimdeBot
//#define BOTtoken "5161374031:AAHOyv1Mv84vmkxHAnHd-zt-loqEQZkLCRA"   // evimbirBot
// Use @myidbot to find out the chat ID of an individual or a group
// Also note that you need to click "start" on a bot before it can message you
#define CHAT_ID "1526975541"
WiFiClientSecure client;
UniversalTelegramBot bot(BOTtoken, client);
// Runs whenever the reedswitch changes state
ICACHE_RAM_ATTR void changeDoorStatus() {
  // Serial.println("State changed");
  changeState = true;
  // Serial port for debugging purposes
  // Read the current door state
  pinMode(reedSwitch, INPUT_PULLUP);
  state = digitalRead(reedSwitch);
  // Set LED state to match door state
  pinMode(led, OUTPUT);
  digitalWrite(led, !state);
  // Set the reedswitch pin as interrupt, assign interrupt function and set CHANGE mode
  attachInterrupt(digitalPinToInterrupt(reedSwitch), changeDoorStatus, CHANGE);
  // Connect to Wi-Fi
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  client.setCACert(TELEGRAM_CERTIFICATE_ROOT); // Add root certificate for api.telegram.org
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  bot.sendMessage(CHAT_ID, "Bot started up", "");
  if (changeState){
    if(currentMillis - previousMillis >= interval) {
      // If a state has occured, invert the current door state
        state = !state;
        if(state) {
          doorState = "closed";
        else{
          doorState = "open";
 //       changeState = false;
        Serial.println(state);
        Serial.println(doorState);
        //Send notification
        bot.sendMessage(CHAT_ID, "The door is " + doorState, "");
        Serial.println(CHAT_ID);
What happens when you modify the sendMessage in loop to just say...
bot.sendMessage(CHAT_ID, doorState, "");
Maybe you will need to prebuild the message instead of trying to construct it in sendMessage on the fly
Thank you for your suggestions. I tried both solutions. the result did not change.
It also only sends a single message before entering the Loop.
I just tested using the below code and it worked without error, sending the initial "Bot started up" message from setup() and then the millis() value every 10 seconds after that from loop()
#include <ESP8266WiFi.h>
// Wifi network station credentials
#define WIFI_SSID "YOUR_SSID"
#define WIFI_PASSWORD "YOUR_PASSWORD"
// Telegram BOT Token (Get from Botfather)
#define BOT_TOKEN "XXXXXXXXX:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
// Use @myidbot (IDBot) to find out the chat ID of an individual or a group
// message you
#define CHAT_ID "175753388"
X509List cert(TELEGRAM_CERTIFICATE_ROOT);
WiFiClientSecure secured_client;
UniversalTelegramBot bot(BOT_TOKEN, secured_client);
 // attempt to connect to Wifi network:
  Serial.print("Connecting to Wifi SSID ");
  Serial.print(WIFI_SSID);
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  secured_client.setTrustAnchors(&cert); // Add root certificate for api.telegram.org
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.print("\nWiFi connected. IP address: ");
  Serial.print("Retrieving time: ");
  configTime(0, 0, "pool.ntp.org"); // get UTC time via NTP
  time_t now = time(nullptr);
  while (now < 24 * 3600)
    Serial.print(".");
    delay(100);
  Serial.println(now);
  delay(10000);
  String myText = (String)millis();
  Serial.println(myText);
  bot.sendMessage(CHAT_ID, myText, "");
Hi.
I couldn't run your code because I don't have an 8266 board.
Sara say on her Web site :
"This example is not compatible with the ESP8266 board."
Sorry.
Here is an example tested on the ESP32
#include <WiFi.h>
//#include <ArduinoJson.h>
// message you
  secured_client.setCACert(TELEGRAM_CERTIFICATE_ROOT); // Add root certificate for api.telegram.org
    Serial.print(".");
    Serial.print(".");
    delay(100);
  delay(20000);
I copied your code, ran it, there is no problem with serial, but only "Bot started up" comes to the phone.
After the "Bot started up" message it will take about 20 seconds for the next and subsequent ones to arrive.
If the first message arrives you would expect everything is working okay and other messages should also arrive for you. I cannot think of anything else to suggest apart from re-installing the ESP32 core (I'm running 1.0.6 core, not the latest one) and UniversalTelegramBot library. also check the UniversalTelegramBot github as this issue seems to match your problem.
Hi
The link you gave is exactly my problem. However, what I read there is beyond my software knowledge.
I had success on another PC today. This shows that the problem is in the library files. I will compare the library versions on my first pc with the other pc.
Thank you for your interest..
The easy answer is to use the Boards Manager in the Arduino IDE to install a different version of the ESP32 core. Sounds like your running core 2.0.2 and downgrading to use 2.0.1 will fix your problem.
You are totally right in your suggestion, after installing 2.0.1 it worked fine.
Thank you so much.
