as the topic says i cant run arduino-ide as root on wayland it shows me this error
/usr/bin/arduino-ide: line 3: [: =: unary operator expected
Arduino IDE 2.3.3
Skipping frontend application configuration customizations. Running in dev mode.
Starting backend process. PID: 62038
Authorization required, but no authorization protocol specified
[62021:0929/134622.568337:ERROR:ozone_platform_x11.cc(240)] Missing X server or $DISPLAY
[62021:0929/134622.568396:ERROR:env.cc(255)] The platform failed to initialize. Exiting.
[1] 62018 segmentation fault sudo arduino-ide --no-sandbox
and when i run arduino without root it cant upload my codes
printf("test");
printf("hello world");
my simple code for testing arduino if it works or not i pressed reset button but it shows this error
Sketch uses 1948 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 33 bytes (1%) of dynamic memory, leaving 2015 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "/dev/ttyUSB0": Permission denied
and if i somehow get the port to work it says that stk500 cant sync and programmer is not responding
