I cant see the problem with this code. It just hangs - Any help appreciated
folks
I need help with some code.
its pretty simple, but I cant see what Im doing wrong.
I have a couple of Interrupts and I'm wondering if maybe I've set them up incorrectly and its causing the issue I'm seeing?
I'm listening on Pin 2 for a digital signal coming from a speed sensorr that is measuring distance travelled.
For each 10 meters I get 63 pulses.
The timer interrupt fires every second and is supposed to display various stats including KPH and distance travelled.
For some reason the serial.print statements in the 'timeElapsed' function cause the program to hang.
If I delete any 2 statement, it works fine.
Code is below
Sam
#include <PinChangeInt.h>
#include <PinChangeIntConfig.h>
#include <TimerOne.h>
int state=0;
int burp=0;
int burpsPerSecond=0;
double offset =0.0;
double previousOffset=9.9;
double startingValue=1.50;
int metersTravelled=0;
int oneHundredMeters=0;
int kilometers=0;
#define PIN 2
#define AnalogPIN 1
	Serial.println("Reading Pin 2  - interrupt test");
        pinMode(PIN, INPUT);
	digitalWrite(PIN, HIGH);
	PCintPort::attachInterrupt(PIN, risingPinDetected,RISING);
        Timer1.initialize(1000000);                 // initialize timer1, and set a 1 second period
        Timer1.attachInterrupt(timeElapsed);   // attaches callback() as a timer overflow interrupt
  offset = analogRead(AnalogPIN) * ((5.0 / 1023.0)/10) + startingValue; // check if the trim pot value has changed - this is the offset for fine adjustment
void risingPinDetected()	//on the rising edge of the currently inturrupted pin
	PCintPort::detachPinChangeInterrupt(PIN);
	burp++;            //  burps per distance
        burpsPerSecond++;  //  burps per second (used in timeElapsed function)
        if(burp==63)       // 63 = 10 meters travelled
          metersTravelled+=10;
          if(metersTravelled>=100)
            metersTravelled=0;
            oneHundredMeters+=100; // keep track of 1/10 of a Kilometer
            if(oneHundredMeters>=1000)
              oneHundredMeters=0;
               kilometers++;
           burp=0;
void timeElapsed()
       Serial.print("Burps per second [");
       Serial.print(burpsPerSecond); // burps per second
       Serial.print("] offset [");
       Serial.print(offset );
       Serial.print("] KPH [");
       Serial.print(burp / offset);
       Serial.print("] Meters x 10 [");
       Serial.print(oneHundredMeters );
       Serial.print(" Total Kilometers: ");
       Serial.print(kilometers );
       Serial.println("]");
       burpsPerSecond=0;
Moderator edit: Why is it so difficult to do such a simple thing as code tags?
How big is the Serial output buffer?
Serial.print() uses it's own set of interrupts. Could it be causing a conflict?
You cannot use Serial.print in an interrupt handler.
Also, why do you detach, then re-attach the risingPinDetected interrupt?
Regards,
Ray L.
RayLivingston:
You cannot should not use Serial.print in an interrupt handler.
. . .which is why I asked the question about the size of the serial buffer :wink:
If you read the original post, it says
Why in the world would you have an interrupt driving display code. Do you really think your human eyes could tell if the display update was a few hundred microseconds off?
sammypati:
Hanging a program with Serial.print while handling an interrupt is just like shooting yourself in the foot when handling a gun:
Don't try this at home, kids!
Why are you doing pin change interrupts on an external interrupt pin? That's like doing SoftwareSerial on the hardware serial pins - possible but ridiculous.
