I Can't Send Request With NODEMCU When A Key Press
Hi there I want to send a request to the server as a get method with URL parameters when a key pressed with nodemcu. But I Cant Do This Work.
my request sending code is below:
#include <ESP8266WiFi.h>
const char* ssid = "your-ssid";
const char* password = "your-password";
const char* host = "";
	delay(10);
	Serial.print("Connecting to ");
	Serial.println(ssid);
	WiFi.mode(WIFI_STA);
	WiFi.begin(ssid, password);
	while (WiFi.status() != WL_CONNECTED)
		Serial.print(".");
	Serial.println("");
	Serial.println("WiFi connected");
	Serial.println("IP address: ");
int value = 0;
	delay(5000);
	++value;
	Serial.print("connecting to ");
	Serial.println(host);
	WiFiClient client;
	const int httpPort = 80;
	if (!client.connect(host, httpPort)) {
		Serial.println("connection failed");
		return;
	String url = "/";
	/* url += "?param1=";
	url += param1;
	url += "?param2=";
	url += param2;
	Serial.print("Requesting URL: ");
	Serial.println(url);
	client.print(String("GET ") + url + " HTTP/1.1\r\n" + "Host: " + host + "\r\n" + "Connection: close\r\n\r\n");
	unsigned long timeout = millis();
	while (client.available() == 0) {
		if (millis() - timeout > 5000)
			Serial.println(">>> Client Timeout !");
			client.stop();
			return;
	while (client.available())
		String line = client.readStringUntil('\r'); Serial.print(line);
	Serial.println("closing connection");
And My Key Press Code Detector Is below:
const int button = 8;
int temp = 0;
  pinMode(button, INPUT);
  temp = digitalRead(button);
   if (temp == HIGH) {
      Serial.println("LED Turned ON");
      delay(1500);
   else {
      Serial.println("LED Turned OFF");
      delay(1500);
And My Circuit Is:
NodeMcu => MicroSwitch
VIN => C
D0 => NO
G => 10k => NO
How Can I Make It When That Key Pressed It Send Request?
Main Code
const char* ssid = "MobinNet1365";
//replace with your own wifi ssid
const char* password = "G12229M1Q64"; //replace with your own //wifi ssid password
const char* host = "webhook.site";
int temp = 0;
  delay(10);
  while (WiFi.status() != WL_CONNECTED){
    Serial.print(".");
  Serial.println("");
  if (temp == HIGH) {
    WiFiClient client;
    String url = "/df35c8cd-0398-4c92-b55f-b9e36629b309";
    url += "?switche=";
    url += "1";
Problem:
ets Jan 8 2013,rst cause:4, boot mode:(3,7)
wdt reset
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v951aeffa
~ld
the 'main code' sketch doesn't connect to server, has an incomplete url, doesn't read the response...
You should post code by using code-tags
There is an automatic function for doing this in the Arduino-IDE
just three steps
  1. press Ctrl-T for autoformatting your code
  2. do a rightclick with the mouse and choose "copy for forum"
  3. paste clipboard into write-window of a posting
best regards Stefan
