Hi guys, i’m trying to set up a rain sensor, but i can’t find the error, i’ve read a lot of problems that were similar, but i was unsuccessful.
The problem is in the " int pino_d = D0", that appears “D0 was not declared in this scope”
Sorry for the bad english!
Thanks for the help!!
// Projeto Curto Circuito - Estação Meteorológica - Sensor de Chuva
//Chuva
int pino_d = D0; // Pino ligado ao D0 do sensor
int pino_a = A0; // Pino ligado ao A0 do sensor
int val_d = 0; // Armazena o valor lido do pino digital
int val_a = 0; // Armazena o valor lido do pino analógico
// Sensores INPUT
pinMode(pino_d, INPUT);
pinMode(pino_a, INPUT);
// Armazena os valores de leitura dos sensores nas variáveis
val_d = digitalRead(pino_d);
val_a = analogRead(pino_a);
// Se a leitura analógica for menor que 300
if ( val_a < 300) { // Chuva intensa
// Se a leitura analógica for menor que 500 e maior que 300
if (val_a <= 500 && val_a >= 300) { // Chuva moderada
// Se a leitura analógica for maior que 500
if ( val_a > 500) { // Sem previsão de Chuva
ESP8266_Standalone:3:14: error: 'D0' was not declared in this scope
C:\Users\gusta\OneDrive\Documentos\Arduino\ESP8266_Standalone\ESP8266_Standalone.ino: In function 'void setup()':
ESP8266_Standalone:9:14: error: 'D0' was not declared in this scope
C:\Users\gusta\OneDrive\Documentos\Arduino\ESP8266_Standalone\ESP8266_Standalone.ino: In function 'void loop()':
ESP8266_Standalone:19:14: error: 'D0' was not declared in this scope
exit status 1
You don't say what board you are using, but the IDE aliases the ESP data pins as D0, D1, etc. If you are using the Uno, you have to use the Uno pin numbering convention.
SteveMann:
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a timeout from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
