I can't stop the motor
Hi, I've written a program for controlling the position of a DC motor with PID. I have a predesigned circuit with a dc motor and a IC driver that has one input for motor direction and one for PWM. I should control the position of a handle on a rail that is connected to the motor until it reaches a setpoint distance. During the time that handle is moving if the opto-sensor detects the handle the motor should be turned of and not to control the handle. My problem is that handle starts to move and motor through a PID controls the handle movement, but when opto-sensor detects the handle motor continuously tries to control the handle and isn't zero. Although I put the PWM value zero. I send my codes here. Is there any one here to see what is the problem of my program?
#include <Encoder.h>
#define ENCA1 15 // encoderA motor connected to 15th microcontroller pins
#define ENCB1 14 // encoderB connected to 14th microcontroller pins
#define PWM1 6   //  analog pin
#define PH1 19  //digital pin, output, sets the direction
#define opto_rev 8  // optocopulers of two ends
#define opto_fwd 10
float a,b;
int direction =0;    //direction value 0: CCW, 1: CW. - Stored value
// PID parameters
float kp = 1.6;
float kd = 0.025;
float ki = 0.01;
float controlSignal=0;
float pwmVal=0;   // PWM shows the power of motor to control speed
int Error=0;
// set target position
int target = 500;
int prevPos =0;          // previous position of motor
volatile int newPos = 0; //  new position of motor
float prevT = 0;
float prevError = 0;
float eintegral = 0;
long unsigned int flag=0;
  // Motor Encoder
  pinMode(ENCA1,INPUT);
  pinMode(ENCB1,INPUT);
  attachInterrupt(digitalPinToInterrupt(ENCA1),readEncoder1,CHANGE);
  attachInterrupt(digitalPinToInterrupt(ENCB1),readEncoder2,CHANGE);
  pinMode(opto_rev, INPUT);
  pinMode(opto_fwd, INPUT);
  pinMode(PWM1,OUTPUT);
  pinMode(PH1,OUTPUT);
  Serial.println("target pos");
void loop(){
  while (digitalRead(opto_fwd)==LOW){
    calculatePID();
   setMotorSlider();
   prevPos = newPos;
 pwmVal=0;
 analogWrite(PWM1, pwmVal);
  // with defining this condition we can see the results in every 500000, since the output prints were two much
  if (flag++ == 500000){
    Serial.print(target);
    Serial.print(",");
    Serial.print(pwmVal);
    Serial.print(",");
    Serial.print(Error);
    Serial.print(",");
    Serial.println(direction);
    Serial.print(newPos);
    Serial.print(",");
    flag=0;
} // main loop ends
  // defining the interrupt function for finding motor position
void readEncoder1(){
  a=digitalRead(ENCA1);
  b=digitalRead(ENCB1);
  if(a==b){
    newPos++; // :CW direction
  else{     // :CCW direction
    newPos--;
void readEncoder2(){
  if(a !=b){
    newPos--;
 //Determine speed and direction based on the value of the control signal
void setMotorSlider(){
   // motor direction
   if (controlSignal < 0) {   // negative value of control signal means motor direction is counterclockwise
   direction = -1;
   else if (controlSignal > 0){
    direction = 1;
   else{
    direction = 0;
   // motor speed
   pwmVal = fabs(controlSignal);  //PWM values cannot be negative and have to be integers
   if (pwmVal > 255){
    pwmVal = 255;
   if (pwmVal <50 && Error !=0){
    pwmVal = 50;
   if (direction == 1){
    digitalWrite(PH1, HIGH);
   else if (direction == -1){
    digitalWrite(PH1, LOW);
   //Then we set the motor speed
void calculatePID(){
 //Determining the elapsed time
 long currT = micros();
 float deltaT = ((float) (currT - prevT))/( 1.0e6 );
 if (deltaT > 0){
  prevT = currT;
  // Error
  Error = target-prevPos;
  // derivative
  float dedt = (Error-prevError)/(deltaT);
  // integral
  eintegral = eintegral + Error*deltaT;
  // control signal
  controlSignal = kp*Error + kd*dedt + ki*eintegral;
  // store previous error
  prevError = Error;
 }  // if
Your code never reads the optocouplers.
Either the forum just re-booted, or you created two profiles and two topics with the same subject and deleted your other profile. Probably the forum dumped my post.
Your post disappeared for a bit.
I flagged it as a database issue.
My profile/activity showed nothing on my earlier post.
Sorry, I had 2 similar posts. In one of them, I'd forgotten to post the correct codes and I wanted to be deleted. I didn't know that it could be edited.
Now my correct codes are here.
Sorry for my mix up earlier... on with the show.
Now that you have updated your sketch, what is your observation of how it works, and how is it intended to work?
Your current sketch shows no use of this...
Thank you for your reply.
I have 2 opto-couplers (opto-rev and opto-fwd) in both ends that detect if the handle has reached the ends or not. I tested the motor without PID controller and it was OK and could change the directions through the opto-sensors.
But in this stage I don't need the opto-rev and I just want to start to move from the point that there is opto-rev. Then through the PID control command the handle moves, finds the positions and also controls the PWM to reach a target (that is 500).
But during its movement if the opto-fwd finds the handle should stop the motor completely. But unfortunately, this doesn't happen! Although the opto-fwd detects the handle, the motor still tries to continue the control and motor and as a result, the handle doesn't stop.
I have already responded, see one of the other posts.
To a post similar to mine? I read them but I didn't find something related! Could you please give me the link?
Sorry I have read a lot of posts and no longer remember where I saw it.
