I can't understand the problem - stopwatch + thermoresistors + lcd buzzer
I can’t understand the problem - stopwatch + thermoresistors + lcd buzzer.
I tried to make this program but there is a problem with thermistors and their library although it is installed on my computer. The program should make the buzzer ring once per minute for 10 minutes, mark the chronometer on the LCD in the lower center and, at the top left, the temperature of a thermistor and at the top right the temperature of the second thermistor.
#include <LiquidCrystal.h>
#include <Thermistor.h>
Thermistor temp1(A0);
Thermistor temp2(A1);
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  pinMode(LED_BUILTIN, OUTPUT);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("hello, world!");
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(60000);                       // wait for a second
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis() / 1000);
  Serial.print("Temperatura no Sensor eh: ");
  Serial.print( temp1.getTemp());
  Serial.println("*C");
  Serial.print("Temperature of sensor 2: ");
  Serial.print( temp2.getTemp());
I would like to know what the problem is and if anything, to receive the program already written by you pls.
ps. it’s for school and I want to look good
You forgot an important part, to tell us what is the actual problem :wink: Aka, what does happen and what did you expect to happen?
What does the code do (or not do) that is different from what you want?
60000 milliseconds is a slightly longer than a second.
