I can't upload...again
I haven't used Arduino in a while and now when I upload it says this:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x71
I can't figure it out so if anyone can help me it would be great. Thanks! ;)
its a serial port issue i believe. I'm having the same problem :(
Basically, if you're connecting via USB, it's not recognized on your computer. It's super frustrating.
I have the same problem - using Nano from China.
I may check the port I'm using...
hi, i have the same problem as issohard above although i am connected via usb and use com 4 in fact it is very frustrating. if you can not use usb what then??? grzzz, rickwaver
