and i put a wire to connect arduino nano GND to RST
and i downloaded the esp8266 board and picked the generic esp8266 board
and from there i uploaded this modified blink program
Blink
Turns an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
the correct LED pin independent of which board is used.
If you want to know what pin the on-board LED is connected to on your Arduino
model, check the Technical Specs of your board at:
https://www.arduino.cc/en/Main/Products
modified 8 May 2014
by Scott Fitzgerald
modified 2 Sep 2016
by Arturo Guadalupi
modified 8 Sep 2016
by Colby Newman
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/Blink
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(2, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(2, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(2, LOW); // turn the LED off by making the voltage LOW
i always get this error "esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
i do not know why even though Arduino ide says this
but it then stops working altogether
esptool.py v2.8
Serial port COM10
Connecting......................................____
yes it does matter, you would not want the ESP to be connected to Rx/Tx whilst uploading the code and you would need to cross the cables.
so you are trying to use the Nano as a Serial adapter.
Are you 100% sure your ESP-01 pins (Rx especially) are 5V tolerant? I think they are only OK with 3.3V
Assuming it's OK to send 5V to the ESP Rx for your module, I would try to hold reset LOW (wire reset to GND) on the Nano so that the Nano's bootloader does not come make a mess during the transmission.
if 5v is not OK, you can do a small voltage divider with 2 resistors (1KΩ and 2.2KΩ should do) to lower the voltage on Rx near 3.3V
Once code is uploaded you remove GPIO0 from GND and reboot the ESP.
i reached the point where i can upload programs, but nothing happens
Says Yes and no at the same time without specifying what is happening in detail.
So what does happen in detail?
If you connect your ESP01 through a USB-to-serial-adapter and you click upload what do you see for messages in the Arduino-IDE?
If I remember right the ESP01 needs some pins connected to ground to enter flashing mode did you do all these steps?
If you can afford to buy a ESP8266 Wemos D1 mini or a ESP32-nodeMCU-board
Take such a device. Plug gin in USB-cable and upload works
best regards Stefan
best regards Stefan
Many times the ESP-1 doesn't get connected properly. ON the ESP-01 make sure that
VCC - > 3.3v
CH_PD -> 3.3v
RST -> 3.3v (this is omitted in many tutorials, but the ESP won't work if you don't pull it high)
GND -> GND
GPIO0 -> (GND for uploading) (3.3v or free-floating for normal operation)
GPIO2 -> 3.3v or free-floating
GPIO3 (RX) -> via voltage divider to either nano RX (for upload) or nano TX for communicating over the UART (not applicable in your case)
GPIO1(TX) -> 3.3v or free-floating or connected to either nano TX (for upload) or nano RX for communication over the UART.
