I cant upload the sketch through CP2102
I have brand new ATmega328 chip(TQFP 32 Pin).
First I cant burn the boot loader.
Second I used usbasp for burning the boot loader. Then I try to use the CP2102 for upload the sketches. Bu I got this errors
Arduino: 1.6.13 (Windows 7), Board: "Arduino/Genuino Uno"
\Temp\arduino_build_802909/PWM_Zero_cross.ino.hex"
Sketch uses 1,176 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 15 bytes (0%) of dynamic memory, leaving 2,033 bytes for local variables. Maximum is 2,048 bytes.
D:\arduino-1.6.13\hardware\tools\avr/bin/avrdude -CD:\arduino-1.6.13\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Suresh\AppData\Local\Temp\arduino_build_802909/PWM_Zero_cross.ino.hex:i
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "D:\arduino-1.6.13\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x82
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
What is the problem.
1.I think The boot loader doesn't.
2.I used clock 16Mhz and 22pf.
3.which board I need to choose in boards menu before upload ?.(Because uno, mini, nano all are used 328 chip)
I have attached my circuit. please find.
