I can't upload to my Arduino
So im new to all of this. I just got a chinese arduino nano to complete a personal proyect and need to upload some code to it. I've tried to do it from the arduino app but when i press upload it stays uploading for a very long time and then gives me this error
Arduino:1.8.9 (Windows 10), Tarjeta:"Arduino/Genuino Micro"
avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = "�"; type = �
Software Version = i.
It is an Arduino nano but the program only works if I put it as Genuino/micro, in nano mode it gives an error saying the board isn't the type selected
Also when I try to get information of the board from the arduino software it says the board is unknown.
I have already downloaded the software for this chinese arduinos and whatched many tutorials related but still no solution? Do you know what can be the cause of this?
Thanks
It looks like you selected the wrong board type. It should say "Nano" not "Micro"
I finally fixed it. The problem is that I was trying to use the nano for a button matrix but it seems it doesn't support it. I tried in a micro I have and everything work perfectly
Sorry, but I don't understand what you are saying.
Can you please post your code
I followed this tutorial (MAKE THIS BUTTON BOX | 32 FUNCTION w ENCODERS - YouTube) and used the code provided in the description but with a Arduino nano when you can't use this board for this particular case, I changed it for a Arduino micro now and everything worked fine
The reason that you can't use a Nano is that the program uses the Joystick library which the Nano does not support. It has nothing to do with the button matrix itself
