i can't use IRSend and IRRecv with in same program
Hi :). I'm trying to use infaredLED to send out data and listen to infaredReceiver that recieve data back to my Arduino but doesn't work program not go to work in ir.recv command . Here is serial port output with sourcecode below(sry for my bad english :sweat_smile:)
send
send
send
send
send
#include <IRremote.h>
int RECV_PIN = 2;
IRrecv irrecv(RECV_PIN);
IRsend irsend;
decode_results results;
char character  ;
  irrecv.enableIRIn();
  for (int i = 0; i < 3; i++) {
    irsend.sendSony(0xa90, 12); // Sony TV power code
    Serial.println("send");
  if (irrecv.decode(&results))
    Serial.print("recv signal ... ");
    switch (results.value)
    case NULL : /* irsend.sendSony(0xA91, 12);*/
      character = 0xA91 ;
      Serial1.println("character");
    case 0xB90:
    case 0xC90:
    case 0xB91: /*irsend.sendSony(0xA92, 12);*/
      character = 0xA92 ;
    case 0xC91: /*irsend.sendSony(0xA92, 12);*/
      character = 0xA92 ;
    case 0xB92: /*irsend.sendSony(0xA93, 12); */
      character = 0xA93 ;
    case 0xC92: /*irsend.sendSony(0xA93, 12); */
      character = 0xA93 ;
    default:
      character = 0xA93;
      Serial.println("cannot specified data signal @_@");
    delay(100);
    irrecv.resume();               // Receive the next value
I haven't checked your code....but using IRremote...
It is not possible to send IR & receive IR in the same Arduino at the same time. Receive is disabled when sending. Once you send you must re-enable receiving.
Use a TV remote to test the receiving and then use a TV or other device to test the sending.
Also, go thru all of the examples with the library first!
