I chage content string and program hangs/broken.
Hi.
I'm working with a Nano board, a TinyRTC, a OLED display and Arduino IDE 1.8.9.
I have declared two String Pointers Arrays (myStrings and myStringsA ).
When I change some character from that strings and upload code, it doesn`'t works, it is unable to detect Display.
Let me illustrate it. That works fine ( ok... it seems to work) I see on serial monitor logs as I expect, and display show menus an options as I programed, the keyboard and RTC are working weel.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "RTClib.h"
 //.... some code omited ....//
const char *myStrings[] = {
                     "Ajustar Horas",
                     "Ajustar Minutos",
                     "Ajustar el dia",
                     "Ajustar el mes",
                     "Ajustar el anyo",
                     "Ajustar Linea 1",
                     "Ajustar Linea 2",
                     "Ajustar Linea 3",
                     "Ajustar Linea 4",
                     "Ajustar Prioridad"
const char *myStringsA[] = {
                     "Ajustar Horas",
                     "Ajustar Minutos",
                     "Ajustar el dia",
                     "Ajustar el mes",
                     "Ajustar el anyo",
                     "Ajustar Linea 1",
                     "Ajustar Linea 2",
                     "Ajustar Linea 3",
                     "Ajustar Linea 4",
                     "Ajustar Prioridad"
But... this one produce to lcd lib to not detect Display, The only difference is an "X" on de second member of myStringsA :
#include <SPI.h>
#include <Wire.h>
#include "RTClib.h"
                     "Ajustar Horas",
                     "[color=red]Ajustar[/color] Minutos",
                     "Ajustar el dia",
                     "Ajustar el mes",
                     "Ajustar el anyo",
                     "Ajustar Linea 1",
                     "Ajustar Linea 2",
                     "Ajustar Linea 3",
                     "Ajustar Linea 4",
                     "Ajustar Prioridad"
                     "Ajustar Horas",
                     "AjustaX Minutos",    // <<------ SEE HERE !! Unbelievable, this X brokes code!!
                     "Ajustar el dia",
                     "Ajustar el mes",
                     "Ajustar el anyo",
                     "Ajustar Linea 1",
                     "Ajustar Linea 2",
                     "Ajustar Linea 3",
                     "Ajustar Linea 4",
                     "Ajustar Prioridad"
Error is raised by:
 if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3C for 128x64
    Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
What is the relationship between the "X" and the LCD library?
It doesn't seem to make much sense. If the error happened later in the code, I might think that I am referencing the pointers badly. But it fails at the beginning !!
It is as if there was a collision between my variable space and that of the LCD library. If so, how could I avoid it?
I have tried several tests, for example:
  • Change the order in which I declare the variables, to check if the problem is that with the pointers I am accessing where I should not.
  • Change the size of myStrings, to check if with smaller declarations, I don't crush other LCD variables.
I'm sure the problem is with my code or because I misunderstand something about programming, but I can't see what it is.
Can I enable more traces of compilation or linking?
Any ideas? someone with a similar problem?
Thank you.
PD: while writing this post it seems that the chip has been fried. Now I can't even program it .... "The programmer is not responding"
My guess is a RAM problem. String constants need RAM at initialization time if not stored in PROGMEM. As you failed to provide the complete sketch, this is just an educated guess.
