I used a to create an LED object. The twinkle function exists in the object.
Twinkle has a delay function that uses millis () to judge the delayed execution without using the delay function
But I created five led objects at the same time, and the first one executed twinkle
As a result, the other four objects need to wait until the first twinkle is executed.
braked.cpp
BrakedObj.setInit(BRAKE_LED, true);
BrakedObj.twinkle(5, false);
turn.cpp
TurnLeftDefaultObj.setInit(LEFT_TURN_LED_DEFAULT, true);
TurnLeftSecondObj.setInit(LEFT_TURN_LED_SECOND, true);
TurnRightDefaultObj.setInit(RIGHT_TURN_LED_DEFAULT, true);
TurnRightSecondtObj.setInit(RIGHT_TURN_LED_SECOND, true);
object.cpp
ledobj::twinkle(int frequency, bool state)
int i = 0;
next_duration = millis() + duration;
openLed();
while (i < frequency)
if (millis() > next_duration)
Serial.println("=====i=====");
Serial.println(i);
i++;
if (ledOpen)
ledobj::closeLed();
ledobj::openLed();
if (i >= frequency && !state)
closeLed();
It looks like the problem is the while loop. Consider using if instead of while so that the code is not blocked in the while loop
guix
4
Yes, you have created a more useful delay()
function, it's still blocking the rest of your code
Try something like this example : led_blink_class_example.ino - Wokwi Arduino and ESP32 Simulator
Thank you. I've solved the problem
Yes, it looks really stupid. I've solved it in a different way
For the benfit of others who may find this topic please share your solution
I canceled while, exposed a method in the object, and used the loop function to execute the exposed method. The original while was changed to if
system
Closed
10
