i created smthing!(a dog feader)
try fixing it tho :frowning:
 #include <Servo.h>
Servo myservo;
int ledPin = 13;                // choose the pin for the LED
int inputPin = 2;               // choose the input pin (for a pushbutton)
int val = 0;                    // variable for reading the pin status
int pos = 0;
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
     // declare LED as output
  pinMode(inputPin, INPUT);     // declare pushbutton as input
void loop(){
  val = digitalRead(inputPin);  // read input value
  if (val == HIGH) {            // check if the input is HIGH
  for(pos = 0; pos < 180; pos += 8)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  }  // turn LED OFF
  for(pos = 180; pos>=1; pos-=8)     // goes from 180 degrees to 0 degrees
its a function for my auto dog feeder
maybe you need to add Servo::refresh();
#include <Servo.h>
Servo myservo;
int pos = 0;
void loop(){
myservo.write(pos); // tell servo to go to position in variable ‘pos’
Servo::refresh();
} // turn LED OFF
Servo::refresh();
