i want my arduino to show the value of ipd response by serial input(start marker and end marker), but it doesn't work, why?
#include <SoftwareSerial.h>
#include <string.h>
#define esp8266 Serial1
#define SSID "test" // put here the name of your wifi network
#define PASS "lolman123"
#define IP "184.106.153.149"
int counter = 120;
String keep;
String valuetosend;
const byte maxDataLength = 30; // maxDataLength is the maximum length allowed for received data.
char receivedChars[31] ;
boolean newData = false;
String GET = "GET /update?key=FYPW04TOYR3FX2QH&"; // put here your thingspeak key
String GET1 = "field1=";
String readGET1 = "GET https://api.thingspeak.com/channels/864152/fields/1/last";
esp8266.begin(115200);
esp8266.println("AT");
delay(5000);
if(esp8266.find("OK")){
connectWiFi();
Serial.println("WIFI CONNECTED");
pinMode(7, INPUT_PULLUP);
pinMode(8, INPUT_PULLUP);
newData = false;
int readBtn = digitalRead(7);
int readSend = digitalRead(8);
if (readBtn == 0)
ReadLastEntryThingSpeak();
if (readSend == 0)
WriteThingSpeak();
boolean connectWiFi(){
esp8266.println("AT+CWMODE=1");
delay(2000);
String cmd="AT+CWJAP=\"";
cmd+=SSID;
cmd+="\",\"";
cmd+=PASS;
cmd+="\"";
esp8266.println(cmd);
delay(5000);
Serial.println("OK");
return true;
}else{
Serial.println("KO");
return false;
void updateFunction(String valuetosend){
String cmd = "AT+CIPSTART=\"TCP\",\"";
cmd += IP;
cmd += "\",80";
delay(2000);
if(esp8266.find("Error")){
Serial.print("Error1");
return;
cmd = GET + GET1;
cmd += valuetosend;
cmd += "\r\n";
Serial.print(cmd);
esp8266.print("AT+CIPSEND=");
esp8266.println(cmd.length());
if(esp8266.find(">")){
esp8266.print(cmd);
}else{
esp8266.println("AT+CIPCLOSE");
void ReadLastEntryThingSpeak()
cmd += IP;
cmd += "\",80";
delay(2000);
return;
cmd = readGET1;
cmd += "\r\n";
Serial.print(cmd);
esp8266.print(cmd);
}else{
delay(2000);
recvWithStartEndMarkers(); // check to see if we have received any new commands
if (newData) { processCommand(); }
void WriteThingSpeak ()
String valuetosend = String(counter);
updateFunction(valuetosend);
void recvWithStartEndMarkers()
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = ':';
char endMarker = 'C';
if (esp8266.available() > 0)
char rc = esp8266.read();
if (recvInProgress == true)
if (rc != endMarker)
if (ndx < maxDataLength) { receivedChars[ndx] = rc; ndx++; }
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) { recvInProgress = true; }
void processCommand()
Serial.print("Recieved data = "); Serial.println(receivedChars);
newData = false;
The result on output is Receiving data = , but the actual result is Receiving data = 120 because the last entry data of my field 1 is 120
