I didn't wire my buttons up correctly and need help please and thank you (Matrix Included)
I'll start by saying I know very little (and I mean little) about wiring and all of the hardware. It's very possible what I have done so far is completely wrong, but I hope I at least have some of it right.
I've found out about the button matrix looking around online and managed to make one of my own. Although I didn't quite get it right with the wiring. I believe I recognize the problem but I don't know how to deal with it.
I loaded up the code that I downloaded from a yt video and only had to change a few things to get it right with my matrix. Tested it on the pc game controller, and everything seems to work fine, except for two toggle switches.
My On-off-on toggle switch (can be pushed up or down but always reverts back to center pos) only works when I push up on the toggle. I was wondering what I need to do to make pushing the button down work.
Im also wondering How to wire a non led rocker switch up, and how to find or implement a code for this.
Thank you for your time, it's appreciated.
Matrix1
#include <Keypad.h>
#include <Joystick.h>
//DEFINITIONS
#define ENABLE_PULLUPS
#define NUMROTARIES 1 //replace "?" with number of rotary encoders you are using
#define NUMBUTTONS 7 //replace "?"with number of buttong you are using
#define NUMROWS 4 //replace "?" with number of rows you have
#define NUMCOLS 3 //replace "?" with number of columns you have
//BUTTON MATRIX
//first change number of rows and columns to match your button matrix,
//then replace all "?" with numbers (starting from 0)
byte buttons[NUMROWS][NUMCOLS] = {
  {0,1,2},
  {3,4,5},
  {6,7,8},
  {9,10,11}
struct rotariesdef {
  byte pin1;
  byte pin2;
  int ccwchar;
  int cwchar;
  volatile unsigned char state;
//ROTARY ENCODERS
//each line controls a different rotary encoder
//the first two numbers refer to the pins the encoder is connected to
//the second two are the buttons each click of the encoder wil press
//do NOT exceed 31 for the final button number
rotariesdef rotaries[NUMROTARIES] {
  {0,1,22,23,0} //rotary 1
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
  // R_START (00)
  {R_START_M,            R_CW_BEGIN,     R_CCW_BEGIN,  R_START},
  // R_CCW_BEGIN
  {R_START_M | DIR_CCW, R_START,        R_CCW_BEGIN,  R_START},
  // R_CW_BEGIN
  {R_START_M | DIR_CW,  R_CW_BEGIN,     R_START,      R_START},
  // R_START_M (11)
  {R_START_M,            R_CCW_BEGIN_M,  R_CW_BEGIN_M, R_START},
  // R_CW_BEGIN_M
  {R_START_M,            R_START_M,      R_CW_BEGIN_M, R_START | DIR_CW},
  // R_CCW_BEGIN_M
  {R_START_M,            R_CCW_BEGIN_M,  R_START_M,    R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
  // R_START
  {R_START,    R_CW_BEGIN,  R_CCW_BEGIN, R_START},
  // R_CW_FINAL
  {R_CW_NEXT,  R_START,     R_CW_FINAL,  R_START | DIR_CW},
  // R_CW_BEGIN
  {R_CW_NEXT,  R_CW_BEGIN,  R_START,     R_START},
  // R_CW_NEXT
  {R_CW_NEXT,  R_CW_BEGIN,  R_CW_FINAL,  R_START},
  // R_CCW_BEGIN
  {R_CCW_NEXT, R_START,     R_CCW_BEGIN, R_START},
  // R_CCW_FINAL
  {R_CCW_NEXT, R_CCW_FINAL, R_START,     R_START | DIR_CCW},
  // R_CCW_NEXT
  {R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
//BUTTON MATRIX PART 2
byte rowPins[NUMROWS] = {14,16,10,9}; //change "?" to the pins the rows of your button matrix are connected to
byte colPins[NUMCOLS] = {A3,A2,A1}; //change "?" to the pins the rows of your button matrix are connected to
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
//JOYSTICK SETTINGS
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
  JOYSTICK_TYPE_JOYSTICK,
  32, //number of buttons
  0, //number of hat switches
  //Set as many axis to "true" as you have potentiometers for
  false, // y axis
  false, // x axis
  true, // z axis
  true, // rx axis
  false, // ry axis
  false, // rz axis
  false, // rudder
  false, // throttle
  false, // accelerator
  false, // brake
  false); // steering wheel
const int numReadings = 20;
int readings[numReadings];      // the readings from the analog input
int index = 0;              // the index of the current reading
int total = 0;                  // the running total
int currentOutputLevel = 0;
//POTENTIOMETERS PART 1
//add all the axis' which are enabled above
int zAxis_ = 0;
int RxAxis_ = 0;
//POTENTIOMETERS  PART 2
//Which pins are your potentiometers connected to?
int potentiometerPin1 = A1; //Change "?" to the pin your potentiometer is connected to
const bool initAutoSendState = true;
  Joystick.begin();
  rotary_init();
  for (int thisReading = 0; thisReading < numReadings; thisReading++) {
    readings[thisReading] = 0;
  CheckAllEncoders();
  CheckAllButtons();
  CheckAllPotentiometers();
//POTENTIOMETERS PART 3
//change the details to match teh details above for each potentiometer you are using
void CheckAllPotentiometers(){
  //potentiometer 1
  currentOutputLevel = getAverageOutput(potentiometerPin1);
  zAxis_ = map(currentOutputLevel,0,1023,0,255);
  Joystick.setZAxis(zAxis_);
int getAverageOutput(int pinToRead){
  index = 0;
  total = 0;
  while (index < numReadings){
    readings[index] = analogRead(pinToRead);
    total = total + readings[index];
    index = index + 1;
    //delay (1);
  return total / numReadings;
void CheckAllButtons(void) {
      if (buttbx.getKeys())
       for (int i=0; i<LIST_MAX; i++)
           if ( buttbx.key[i].stateChanged )
            switch (buttbx.key[i].kstate) {
                    case PRESSED:
                    case HOLD:
                              Joystick.setButton(buttbx.key[i].kchar, 1);
                    case RELEASED:
                    case IDLE:
                              Joystick.setButton(buttbx.key[i].kchar, 0);
void rotary_init() {
  for (int i=0;i<NUMROTARIES;i++) {
    pinMode(rotaries[i].pin1, INPUT);
    pinMode(rotaries[i].pin2, INPUT);
    #ifdef ENABLE_PULLUPS
      digitalWrite(rotaries[i].pin1, HIGH);
      digitalWrite(rotaries[i].pin2, HIGH);
    #endif
unsigned char rotary_process(int _i) {
  //Serial.print("Processing rotary: ");
  //Serial.println(_i);
  unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
  rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
  return (rotaries[_i].state & 0x30);
void CheckAllEncoders(void) {
  Serial.println("Checking rotaries");
    unsigned char result = rotary_process(i);
    if (result == DIR_CCW) {
      Serial.print("Rotary ");
      Serial.print(i);
      Serial.println(" <<< Going CCW");
      Joystick.setButton(rotaries[i].ccwchar, 1); delay(50); Joystick.setButton(rotaries[i].ccwchar, 0);
    if (result == DIR_CW) {
      Serial.print(i);
      Serial.println(" >>> Going CW");
      Joystick.setButton(rotaries[i].cwchar, 1); delay(50); Joystick.setButton(rotaries[i].cwchar, 0);
  Serial.println("Done checking");
Your picture only shows two pins on switches. You need a diagram showing the switches you are using.
The left hand side of the two 2-position momentary toggle switches you've depicted both reside at the same 'place' electrically - they're at the cross of the black and yellow wires. Hence, they cannot be distinguished. You will note that no other switch shown has two "same colours" attached, i.e. there's only one blue/green, one blue/orange, etc.
Ok, so it should look something like this?
Matrix0
Thank you so much!
No, you still have the common pins of the toggle switches connected to ground. They should be connected to the yellow wire. The other pins of the left toggle switch should be connected to the orange and dark blue wires. The other pins of the right toggle switch should be connected to the light blue and purple wires.
Ok are talking about like this? Please excuse how dumb I am when it comes to this topic, I clearly have a lot to learn.
Matrixv3
Hello again, sorry to bother you today.
I was wondering if there was a way I can implement the input_pullup into my code from above? If so, how?
If I add a toggle switch to my button box, one connection to ground and the other to pin2. How can I add this in to the sketch?
Thank you.
Okie dokie, thanks again Delta. Sorry to waste your time.
@shotz There is a wealth of example material loaded with the IDE, you may not be aware of it(or you'd already know about INPUT_PULLUP).
For example, in the IDE, look at File|Examples|Digital|DigitalInputPullup - that will help you out.
Thank you camsyca :heart:. I'll read into it some more and When I get home I will play with it some more. May just be in way over my head.
Thank you again, I'm sure I'll be back.
Thank you everyone for bearing with me and helping me out as much as you can.
I did get it to work using the input_pullup example. I do need a lil more help though.
Can anyone point me in the right direction to get this to show up in 'set up USB game game controllers' on PC. To be used as a button box,or keypad etc....
Thank you all
