hi every one
i was just using spiffs to save my things into flash,believing that it promised me with 4MB of space.....i made the program,which works well.....but could some one please suggest how would i see if really it does have access to 4 mb.....
thanks already
void data_saver(){
//saves data in flash if wifi is not connected
digitalWrite(common_power,HIGH);
delay(20);
moisture_reading_function();
temperature_reading_function();
lux_reading_function();
// BME();
// lux_value, Celcius,moisture_reading,ambient_temperature,pressure,humidity
int a=0;
while(a<3){
File myDataFile = SPIFFS.open(filename, "a+");
if (!myDataFile)Serial.println("file open failed");
myDataFile.println("reading :"+String(reading_no));
reading_no++;
myDataFile.println(String(lux_value)+"\n"+String(Celcius)+"\n"+String(moisture_reading)+"\n"+String(ambient_temperature)+"\n"+String(pressure)+"\n"+String(humidity)+"\n"); // Display the file size (26 characters + 4-byte floating point number + 6 termination bytes (2/line) = 34 bytes)
myDataFile.close();
Serial.println("---->>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>here i am");
a++;
data_reader();
// ESP.deepSleep(10);
uint8_t beef[50];
int len;
void data_reader(){
myDataFile = SPIFFS.open(filename, "r"); // Open the file again, this time for reading
if (!myDataFile) Serial.println("file open failed"); // Check for errors
// Serial.println(myDataFile.read());
// Serial.println(".....................");
delay(5000);
char buffer[64];
while (myDataFile.available()){
int l = myDataFile.readBytesUntil('\n', buffer, sizeof(buffer));
buffer[l] = 0;
String(reading)=String(buffer);
Serial.println("reading");
Serial.println(reading);
buffer[l] = 0;
String(lux_value)=String(buffer);
Serial.println("lux_value");
Serial.println(lux_value);
buffer[l] = 0;
String(Celcius)=String(buffer);
Serial.println("Celcius");
Serial.println(Celcius);
buffer[l] = 0;
String(moisture_reading)=String(buffer);
Serial.println("moisture_reading");
Serial.println(moisture_reading);
buffer[l] = 0;
String(ambient_temperature)=String(buffer);
Serial.println("ambient_temperature");
Serial.println(ambient_temperature);
buffer[l] = 0;
String(pressure)=String(buffer);
Serial.println("pressure");
Serial.println(pressure);
buffer[l] = 0;
String(humidity)=String(buffer);
Serial.println("humidity");
Serial.println(humidity);
sendData(String(lux),String( Temperature),String( moisture),String(ambient_temperature),String(pressure),String(humidity));
Serial.println("123654789841258542568525856852568585here i am");
myDataFile.close(); // Close the file
delay(10000);
SPIFFS.remove(filename);//delete the file now
if you want me to u[pload whole code...do tell me ...but its quite long
