#include <Servo.h>
Servo myservo;
int ledPin = 13; // choose the pin for the LED
int inputPin = 2; // choose the input pin (for a pushbutton)
int val = 0; // variable for reading the pin status
int pos = 0;
myservo.attach(9); // attaches the servo on pin 9 to the servo object
// declare LED as output
pinMode(inputPin, INPUT); // declare pushbutton as input
void loop(){
val = digitalRead(inputPin); // read input value
if (val == HIGH) { // check if the input is HIGH
for(pos = 0; pos < 180; pos += 8) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
} // turn LED OFF
for(pos = 180; pos>=1; pos-=8) // goes from 180 degrees to 0 degrees
its a function for my auto dog feeder
what it does is when odie is nearby(odie = my dog) and the motion sensor isint covered in food(i programmed it by hacking it so it knows when he is eating)
but when he is nearby, the arduino feeds him by droping food in his dish!
