I don't know what Wrong!
Hello
whenever I try to upload my code into Arduino I get the following code:
Arduino: 1.8.13 (Windows 10), Board: “Arduino Uno”
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\bernardino\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\BERNAR~1\AppData\Local\Temp\arduino_build_900775 -warnings=none -build-cache C:\Users\BERNAR~1\AppData\Local\Temp\arduino_cache_377657 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\bernardino\Documents\Arduino\sketch_mar08a\sketch_mar08a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\bernardino\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\BERNAR~1\AppData\Local\Temp\arduino_build_900775 -warnings=none -build-cache C:\Users\BERNAR~1\AppData\Local\Temp\arduino_cache_377657 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\bernardino\Documents\Arduino\sketch_mar08a\sketch_mar08a.ino
Using board ‘uno’ from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core ‘arduino’ from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard” “C:\Users\BERNAR~1\AppData\Local\Temp\arduino_build_900775\sketch\sketch_mar08a.ino.cpp” -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard” “C:\Users\BERNAR~1\AppData\Local\Temp\arduino_build_900775\sketch\sketch_mar08a.ino.cpp” -o “C:\Users\BERNAR~1\AppData\Local\Temp\arduino_build_900775\preproc\ctags_target_for_gcc_minus_e.cpp” -DARDUINO_LIB_DISCOVERY_PHASE
“C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags” -u --language-force=c++ -f - --c+±kinds=svpf --fields=KSTtzns --line-directives “C:\Users\BERNAR~1\AppData\Local\Temp\arduino_build_900775\preproc\ctags_target_for_gcc_minus_e.cpp”
Compiling sketch…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard” “C:\Users\BERNAR~1\AppData\Local\Temp\arduino_build_900775\sketch\sketch_mar08a.ino.cpp” -o “C:\Users\BERNAR~1\AppData\Local\Temp\arduino_build_900775\sketch\sketch_mar08a.ino.cpp.o”
In file included from C:\Users\BERNAR~1\AppData\Local\Temp\arduino_build_900775\sketch\sketch_mar08a.ino.cpp:1:0:
C:\Users\bernardino\Documents\Arduino\sketch_mar08a\sketch_mar08a.ino: In function ‘void loop()’:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:40:14: error: expected unqualified-id before numeric constant
#define HIGH 0x1
C:\Users\bernardino\Documents\Arduino\sketch_mar08a\sketch_mar08a.ino:35:22: note: in expansion of macro ‘HIGH’
digitalWrite(blue. HIGH);
exit status 1
Error compiling for board Arduino Uno.
Can I please get some help?!
Code:
int red = 1;
int green = 2;
int blue = 3;
int potentiometer = A5;
pinMode(red, OUTPUT);
pinMode(green, OUTPUT);
pinMode(blue, OUTPUT);
int value;
value = analogRead(potentiometer);
if(value >= 0 && value <= 300){
digitalWrite(red, HIGH);
digitalWrite(green, LOW);
digitalWrite(blue, LOW);
else if(value > 300 && value <= 600){
digitalWrite(red, LOW);
digitalWrite(green, HIGH);
else if(value > 600 && value <= 900){
digitalWrite(blue, HIGH);
else{
Serial.print(value);
You have a . instead of a ,
  digitalWrite(blue. HIGH); // <-- here
