I don't know why it stops after three hours.
#include <DueTimer.h>
#include <SD.h>
void setup(){
  Timer0.attachInterrupt(CHECK_SDCARD).start(5000000);
void CHECK_SDCARD(){
  if (!SD.begin(chipSelect)) {
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
  if (!volume.init(card)) {
  uint32_t volumesize;
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();       // we'll have a lot of clusters
  volumesize /= 2;                           // SD card blocks are always 512 bytes (2 blocks are 1KB)
  root = SD.open("/");
  float all_files_size = printDirectory(root, 0);
  //SerialUSB.println(all_files_size);
  bool removeFlag = false;
  if(all_files_size > ((float)volumesize-15000000)){ //
   removeFlag = true;
  if(removeFlag){
    target_num = checkMin(ename_int, 10);
    memset(ename_int, 0, sizeof(ename_int));
    target_num = 0;
  Flag08 = true;
inline float printDirectory(File dir, int numTabs) {
  float SD_LIMIT_SIZE = 0;
  byte i = 0;
  while (true) {
    File entry =  dir.openNextFile();
    if (! entry) {
      // no more files
    String ename = String(entry.name());
    if(ename.substring(4,8).toInt() - setvalue >= 0){
       ename_int[i] = ename.substring(0,8).toInt();
       i++;
    if (entry.isDirectory()) {
      printDirectory(entry, numTabs + 1);
      SD_LIMIT_SIZE = SD_LIMIT_SIZE + (double)entry.size()/1024.0;
    entry.close();
  return SD_LIMIT_SIZE;
uint32_t checkMin(uint32_t * array, int size)
  uint32_t minimum = array[0];
  for (int i = 0; i < size; i++)
    if (array[i] == 0){
    }else if (array[i] < minimum) minimum = array[i];
  return minimum;
My Arduino Due check the SDCARD capacity every 5 seconds
When all file sizes exceeded 15GB, the delete flag was enabled.
But exactly this code stops after about three hours.
(It works with other code.)
I thought it was other code problem at first, but if I remove the code above
It worked normally for 24 hours.
I’m currently using the SD basic library
But, I will change to sdfat library.
It’s my final goal
my module will create a folder like …
201908/201909/201910 … / 202001/202002 …
And If it does not have enough space, it will delete the oldest folder.
please, give advice.
Is it wise to do that from an interrupt context? I think I would just watch millis and call the function every five seconds before I added extra complexity of a library and an interrupt.
