I use an Intel Galileo. Whenever I try to upload code to me Arduino, it just simply doesn't. I have no idea why, and I have been trying to figure it out for a while now. What I am trying to do is start with pin 3 LOW, and loop [wait 1000 milliseconds], [pin 3 HIGH], [wait 1000 milliseconds], [pin 3 LOW]. I have Digital Pin 3 connected to an LED, with the LED grounded. I am connected to COM3 Serial Port.
Code:
digitalWrite(3, LOW); //Digital Pin 3 LOW (Off)
delay(1000); //Wait 1000 Milliseconds
digitalWrite(3, HIGH); //Digital Pin 3 HIGH (On)
Output:
Sketch uses 57998 bytes (0%) of program storage space. Maximum is 10000000 bytes.
cygwin warning:
MS-DOS style path detected: C:\Users\LawfulDmcBoo\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadGalileo_win.sh
Preferred POSIX equivalent is: /cygdrive/c/Users/LawfulDmcBoo/AppData/Local/Arduino15/packages/Intel/tools/sketchUploader/1.6.2+1.0/clupload/cluploadGalileo_win.sh
CYGWIN environment variable option "nodosfilewarning" turns off this warning.
Consult the user's guide for more details about POSIX paths:
http://cygwin.com/cygwin-ug-net/using.html#using-pathnames
#!/bin/sh
# clupload script to invoke lsz
# Copyright (C) 2014 Intel Corporation
# This library is free software; you can redistribute it and/or
# modify it under the terms of the GNU Lesser General Public
# License as published by the Free Software Foundation; either
# version 2.1 of the License, or (at your option) any later version.
# This library is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# Lesser General Public License for more details.
# You should have received a copy of the GNU Lesser General Public
# License along with this library; if not, write to the Free Software
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
echo "starting download script"
echo "Args to shell:" $*
# ARG 1: Path to lsz executable.
# ARG 2: Elf File to download
# ARG 3: COM port to use.
#path contains \ need to change all to /
path_to_exe=$1
fixed_path=${path_to_exe//\\/\/}
#COM ports are not always setup to be addressed via COM for redirect.
#/dev/ttySx are present. Howwever, COMy -> /dev/ttySx where x = y - 1
com_port_arg=$3
com_port_id=${com_port_arg/COM/}
echo "COM PORT" $com_port_id
tty_port_id=/dev/ttyS$((com_port_id-1))
echo "Converted COM Port" $com_port_arg "to tty port" $tty_port_id
echo "Sending Command String to move to download if not already in download mode"
echo "~sketch downloadGalileo" > $tty_port_id
Args to shell: C:\Users\LawfulDmcBoo\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin C:\Users\LawfulDmcBoo\AppData\Local\Temp\arduino\sketches\74CBFD6E853A3DB15DD37B6E87301E6D/Pin3Blink.ino.elf COM3
COM PORT 3
Converted COM Port COM3 to tty port /dev/ttyS2
Deleting existing sketch on target
#Move the existing sketch on target.
echo "Deleting existing sketch on target"
"$fixed_path/lsz.exe" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" <> $tty_port_id 1>&0
Transfer incomplete
# Execute the target download command
#Download the file.
host_file_name=$2
"$fixed_path/lsz.exe" --escape --binary --overwrite $host_file_name <> $tty_port_id 1>&0
Sending: Pin3Blink.ino.elf
Bytes Sent: 1024/ 57840 BPS:21698 ETA 00:02
Bytes Sent: 9216/ 57840 BPS:166932 ETA 00:00
Bytes Sent: 10240/ 57840 BPS:176493 ETA 00:00
Bytes Sent: 11264/ 57840 BPS:186012 ETA 00:00
Bytes Sent: 12288/ 57840 BPS:199044 ETA 00:00
Bytes Sent: 13312/ 57840 BPS:211728 ETA 00:00
Bytes Sent: 14336/ 57840 BPS:223755 ETA 00:00
Bytes Sent: 15360/ 57840 BPS:234553 ETA 00:00
Bytes Sent: 16384/ 57840 BPS:245707 ETA 00:00
Bytes Sent: 17408/ 57840 BPS:256823 ETA 00:00
Bytes Sent: 18432/ 57840 BPS:266751 ETA 00:00
Bytes Sent: 19456/ 57840 BPS:278767 ETA 00:00
Bytes Sent: 20480/ 57840 BPS:290979 ETA 00:00
Bytes Sent: 21504/ 57840 BPS:303274 ETA 00:00
Bytes Sent: 22528/ 57840 BPS:314575 ETA 00:00
Bytes Sent: 23552/ 57840 BPS:319700 ETA 00:00
Bytes Sent: 24576/ 57840 BPS:330562 ETA 00:00
Bytes Sent: 25600/ 57840 BPS:340651 ETA 00:00
Bytes Sent: 26624/ 57840 BPS:347408 ETA 00:00
Bytes Sent: 27648/ 57840 BPS:348918 ETA 00:00
Bytes Sent: 28672/ 57840 BPS:349918 ETA 00:00
Bytes Sent: 29696/ 57840 BPS:355283 ETA 00:00
Bytes Sent: 30720/ 57840 BPS:360161 ETA 00:00
Bytes Sent: 31744/ 57840 BPS:364479 ETA 00:00
Bytes Sent: 32768/ 57840 BPS:362971 ETA 00:00
Bytes Sent: 33792/ 57840 BPS:361473 ETA 00:00
Bytes Sent: 34816/ 57840 BPS:365456 ETA 00:00
Bytes Sent: 35840/ 57840 BPS:369221 ETA 00:00
Bytes Sent: 36864/ 57840 BPS:373223 ETA 00:00
Bytes Sent: 37888/ 57840 BPS:377175 ETA 00:00
Bytes Sent: 38912/ 57840 BPS:381060 ETA 00:00
Bytes Sent: 39936/ 57840 BPS:384813 ETA 00:00
Bytes Sent: 40960/ 57840 BPS:382900 ETA 00:00
Bytes Sent: 41984/ 57840 BPS:385758 ETA 00:00
Bytes Sent: 43008/ 57840 BPS:377922 ETA 00:00
Bytes Sent: 44032/ 57840 BPS:381288 ETA 00:00
Bytes Sent: 45056/ 57840 BPS:384768 ETA 00:00
Bytes Sent: 46080/ 57840 BPS:388107 ETA 00:00
Bytes Sent: 47104/ 57840 BPS:391385 ETA 00:00
Bytes Sent: 48128/ 57840 BPS:387691 ETA 00:00
Bytes Sent: 49152/ 57840 BPS:389785 ETA 00:00
Bytes Sent: 50176/ 57840 BPS:392754 ETA 00:00
Bytes Sent: 51200/ 57840 BPS:395583 ETA 00:00
Bytes Sent: 52224/ 57840 BPS:398346 ETA 00:00
Bytes Sent: 53248/ 57840 BPS:400990 ETA 00:00
Bytes Sent: 54272/ 57840 BPS:403743 ETA 00:00
Bytes Sent: 55296/ 57840 BPS:406462 ETA 00:00
Bytes Sent: 56320/ 57840 BPS:408930 ETA 00:00
Bytes Sent: 57344/ 57840 BPS:407851 ETA 00:00
Bytes Sent: 57840 BPS:389943
Moving downloaded file to /sketch/sketch.elf on target
Transfer complete
#mv the downloaded file to /sketch/sketch.elf
target_download_name="${host_file_name##*/}"
echo "Moving downloaded file to /sketch/sketch.elf on target"
"$fixed_path/lsz.exe" --escape -c "mv $target_download_name /sketch/sketch.elf; chmod +x /sketch/sketch.elf" <> $tty_port_id 1>&0
Transfer complete
Any help with this would be amazing. Thanks!
