I don't understand this simple code
i found this piece of code in a book and its meant to change the brightness of an led depending on how long you hold the button. and i understand what the code does and what it is meant to do. i understand the logic flip to detect if the switch was pressed or not, but where i get confused is when it says starttime = millis(); because millis is how long since the program has started and it writes that millis number to starttime, but then later on in the code it says mills() - starttime>500, and wouldn't that always be zero because starttime was set to equal millis() in the begining? why does the starttime go up as you hold the button?
If someone could SIMPLY explain this to me that would be very helpful!!! i am very much confused by this program.
down below is the code.
const int led = 9;
const int button1 = 3;
int val = 0;
int oldval= 0;
int state = 0;
int brightness= 128;
unsigned long starttime= 0;
  pinMode(led,OUTPUT);
  pinMode(button1, INPUT);
  val= digitalRead(button1);
  if ((val == HIGH)&& (oldval== LOW))
    state = 1 - state;
    starttime= millis ();
    delay (10);
  if ((val == HIGH) && (oldval == HIGH))
    if (state == 1&& (millis()-starttime)>500)
      brightness++;
      delay (10);
      if (brightness >255)
        brightness = 0;
  oldval= val;
  if (state == 1)
    analogWrite(led, brightness);
  } else{
    analogWrite (led, 0);
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
hold_buttondown.ino (707 Bytes)
millis() returns the amount of time since start
so you call it once to establish a timestamp, call it again later (like 2 seconds) and see the difference
its a constantly running timer from when the chip starts up, using the millis() function just recalls the current number at that point
Not sure but think it takes the last stored "time" and monitors the current "time' and subtracts the last stored "time" from the current "time" and if it is more than 500 milliseconds then it stores the new current "time" as the new last "time" and adds one count to the brightness. By using millis (milliseconds) it allows the program to continue to keep looping so other codes can keep being processed. if delay is used it stops every thing else from being processed until the delay has reached the end time.
