I was using the LM2596 step down to lower from 12V to 5V, powering Arduino and other modules, such like OLED and DS3231 RTC. I accidentally powered my setup with the wire coming from my 12V GND connected to GND in the Arduino. Smoke immediately rose from the Arduino, and it is now dead. While I have already ordered a replacement, my concern is: could this have damaged also the modules connected to Arduino? Note that the modules were all properly powered, i.e., GND to LM2596 GND and VCC to LM2596 out+ (5V).
- It is impossible for us to know what exactly you did.
- 12v might have fried output pins and then other modules.
- Maybe, maybe not
Isn’t there a way for me to test that with a meter?
No
You might be able to test each module, one at a time, with a simple sketch written for that module.
Connect a 220R resistors between the new Arduino GPIO pins and the module pins.
i.e. these resistors would limit fault currents from damaging the new Arduino. -
When you prove the module is okay, you can remove these current limiting resistors.
- I encourage new users to initially use 240R series resistors when first starting out.
Example
Looking at the schematic you did not post it appears you fried everything and should simply replace them.
Thank you for confirming my suspicion that the GNDs were connected anyways. This means that the Arduino and modules saw 5V, right? Maybe it is useful to say that with LM2596 unpowered (both inputs + and - disconnected from 12V source) the Arduino LED turned on when I connected 12V source GND → Arduino GND and LM2596 output + → Arduino 5V.
Question. If this is an adjustable stepdown circuit, as commonly found on Amazon, had you adjusted the output to 5V before connecting any 5V circuitry(such as your Arduino)? Because the LM2596 modules I bought were not pre-set, and the output was, IIRC, about 10V with 12V input, more than enough to fry almost all 5V circuits.
If it's not adjustable, then if you have a meter accessible to you, check that the output is really 5V. You may have to load the converter to at least 100 ma in order for it's regulation to really perform; that's called a minimum load requirement, and it's very common for step-up and step-down circuits.
Mine is adjustable, and I tuned it for 5V output. I had my system running several times previously and everything seemed normal: Arduino and its modules getting 5V. And even now with the fried Arduino removed, I check voltages and it is 5V in the LM2596 output and modules are getting 5V and their power LED are on.
I suspect the Arduino and possibly modules might have seen more than 5V when LM2596 was disconnected from the 12V source? Please see my previous post.
I have experienced problems with converters from the bay, where they controlled the ground and the + went straight through. They may have been designed for creating a - voltage but none of the paper work indicated that although it did work that way. They looked just like the others but the foil pattern was different on the back. If it was the only source as in my project all worked OK, Since then I always check.
This makes zero sense, and is causing confusion. To restate, "I connected the ground of my 12V source to the ground of my Arduino and it blew up.
The only possible scenario is per post #10, but you state that it worked previously, which is impossible if it really is the type of converter referenced in post #10.
So, we stop there.
no, please don’t stop
I need your advice otherwise I risk damaging the new Arduino that has not yet arrived. Everything is expensive where I live, even a clone Arduino
I had problem some time ago with some other cheap converter 12V→5V, when I acidentally made some wires on the 5V side touch each other (so shortcut the 5V for split of second) the chip in the converter burned out and on 5V side was full input voltage (12V).
So test your converter, if it gives 5V now, after the accident, just to be sure.
Hi, @kentdavidge
Have you go any other power source in your project , like batteries?
Can you post some images of your project?
So we can see your component layout.
Thanks.. Tom....
I experience a serious problems to understand the suggestions you wrote. Could you please take a time to explain the issue more clear?
Also drawing a schematic could helps.
When you say smoke, have you taken a close look at the Nano to see where the damage might be?
Look for charred areas or missing tracks on the PCB.
Quite often it's the components at the beginning of the power system that go and most of them are easy to replace. If it got through to the main controller, it might be toast.
It's easily done.
There are several different Nanos, which do you have?
I don’t know how you wired your circuit for that to be true BUT ground for the 12V Should Be (in most cases, Must Be) the same ground for the 5V.
All voltages are electrical potential with respect to ground. 5V and 12V with relation to the same ground are 5 and 12. If each is grounded separately, they may (likely) not be 5 and 12 with respect to each other, the 5V could be 200V with respect to the 12V ground so most often it is VERY IMPORTANT to have a Common Ground (but of course you can wire it different!) to know what voltage one wire has relative to another.
I have had personal relative V of 1000’s of volts relative to other objects in the room until I touched a doorknob or grounding strap though back in the day I may have zapped a keyboard… once.
Fortunately it does ![]()
My 12V source is a battery
It is messy, but I swear I know exactly which wire is which
@GoForSmoke has explained in his post #18 more clearly what I meant to say: please take a look.
I don’t see any damage, but as soon as I connect it to my PC it gets hot to the point of burning my finger if I touch it. Apparently what gets so hot is the 64 legs component, which I believe is the main controller?
this one sir
@GoForSmoke yeah this makes perfect sense and is what I was thinking!
I think the problem is that the tape used wasn't blue.
