I try to figure out how to use the Bounce code from the arduino.cc site. The sketch is by Maik Schmidt and the book "Arduino - A Quick-Start Guide". When using examples from the Bounce.zip file it works, but not the sketch from Schmidt.
This is the error I get when running the sketch:
ae_Binary_dice_digital_tarning_ver2:21: error: no matching function for call to 'Bounce::Bounce(const unsigned int&, const unsigned int&)'
C:\Users\jimmy_000\Documents\Arduino\libraries\Bounce/Bounce.h:40: note: candidates are: Bounce::Bounce()
C:\Users\jimmy_000\Documents\Arduino\libraries\Bounce/Bounce.h:36: note: Bounce::Bounce(const Bounce&)
This is the sketch I try to use:
#include <Bounce.h>
const unsigned int LED_BIT0 = 12;
const unsigned int LED_BIT1 = 11;
const unsigned int LED_BIT2 = 10;
const unsigned int START_BUTTON_PIN = 5;
const unsigned int GUESS_BUTTON_PIN = 7;
const unsigned int BAUD_RATE = 9600;
pinMode(LED_BIT0, OUTPUT);
pinMode(LED_BIT1, OUTPUT);
pinMode(LED_BIT2, OUTPUT);
pinMode(START_BUTTON_PIN, INPUT);
pinMode(GUESS_BUTTON_PIN, INPUT);
randomSeed(analogRead(A0));
Serial.begin(BAUD_RATE);
const unsigned int DEBOUNCE_DELAY = 20;
Bounce start_button(START_BUTTON_PIN, DEBOUNCE_DELAY);
Bounce guess_button(GUESS_BUTTON_PIN, DEBOUNCE_DELAY);
int guess = 0;
handle_guess_button();
handle_start_button();
void handle_guess_button() {
if (guess_button.update()) {
if (guess_button.read() == HIGH) {
guess = (guess % 6) + 1; //
output_result(guess);
Serial.print("Guess: ");
Serial.println(guess);
void handle_start_button() {
if (start_button.update()) {
if (start_button.read() == HIGH) {
const int result = random(1, 7);
output_result(result);
Serial.print("Result: ");
Serial.println(result);
if (guess > 0) {
if (result == guess) {
Serial.println("You win!");
hooray();
Serial.println("You lose!");
delay(2000);
guess = 0;
void output_result(const long result) {
digitalWrite(LED_BIT0, result & B001);
digitalWrite(LED_BIT1, result & B010);
digitalWrite(LED_BIT2, result & B100);
void hooray() {
for (int i = 0; i < 3; i++) {
output_result(7);
output_result(0);
