I Get These Errors?
#include <NewPing.h>
#include <Wire.h>
#include <Servo.h>
// Define Pins Here
const int motorA = 12;
const int motorB = 13;
const int speedA = 3;
const int speedB = 11;
int ping1;
int ping2;
int ping3;
int ping4;
char pingdecision;
#define TRIGGER_PIN 12
#define ECHO_PIN 11
#define MAX_DISTANCE 200
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);  // Defines Stuff For NewPing Library
LiquidCrystal_I2C lcd(0x27,16,2); // Defines Stuff For LCD Library
Servo myservo;
 lcd.init();
 lcd.backlight();
 pinMode(motorA, OUTPUT); // Set As Output
 pinMode(motorB, OUTPUT); // Set As Output
 pinMode(speedA, OUTPUT); // Set As Output
 pinMode(speedB, OUTPUT); // Set As Output
 myservo.attach(9); // Ataches Servo To Pin 9 MUST BE PWM!
check();
if (ping1 < 40) {
  lcd.setCursor(0,0);
  lcd.print("Object Detected");
decision();
switch (pingdecision) {
  case dforwards: // If Decision Returns Forwards Move Forwards
  forwards();
  lcd.setCursor(0,1);
  lcd.print("Forwards");
  case dleft:
  left();
  case dright:
  right();
void check(){
 ping1 = sonar.ping_in();
 return ping1;
void decision() {
  servo_left();
  ping2 = sonar.ping_in();
  delay(100);
  servo_center();
  ping3 = sonar.ping_in();
  delay(100);
  servo_right();
  ping4 = sonar.ping_in();
  delay(100);
  if (ping2 < ping3) {
   pingdecision = dforwards;
  else if (ping3 < ping2) {
   pingdecision = dleft;
  else {
   pingdecision = dright;
return pingdecision;
void servo_left({
  servo.write(50);
void servo_center(){
  servo.write(75);
void servo_right(){
  servo.write(100);
void forwards() {
  digitalWrite(motorA, HIGH);
  digitalWrite(motorB, LOW);
  analogWrite(speedA, maxspeed);
  analogWrite(speedB, maxspeed);
void backwards(){
  digitalWrite(motorA, LOW);
  digitalWrite(motorB, HIGH);
void left() {
void right() {
Errors:
sketch_apr12a.ino: In function 'void loop()':
sketch_apr12a:39: error: 'check' was not declared in this scope
sketch_apr12a:44: error: 'decision' was not declared in this scope
sketch_apr12a:46: error: 'dforwards' was not declared in this scope
sketch_apr12a:52: error: 'dleft' was not declared in this scope
sketch_apr12a:56: error: 'dright' was not declared in this scope
sketch_apr12a:62: error: a function-definition is not allowed here before '{' token
sketch_apr12a:67: error: a function-definition is not allowed here before '{' token
sketch_apr12a:126: error: expected `}' at end of input
Thank You In Advance.
Count the bracket sets in loop(). I think you are short one.
Bad indentation sometimes prevent you from figuring out where the "{" and "}" should be. Try this code:
#include <Wire.h>
#include <Servo.h>
// Define Pins Here
int ping1;
int ping2;
int ping3;
int ping4;
char pingdecision;
#define ECHO_PIN 11
Servo myservo;
	lcd.init();
	lcd.backlight();
	check();
	if (ping1 < 40) {
		lcd.setCursor(0,0);
		decision();
					forwards();
					lcd.setCursor(0,1);
			case dleft:
				left();
			case dright:
				right();
void check(){
	return ping1;
void decision() {
	servo_left();
	delay(100);
	servo_center();
	delay(100);
	servo_right();
	delay(100);
	else {
void servo_left({
  servo.write(50);
  servo.write(75);
void servo_right(){
  servo.write(100);
void forwards() {
void backwards(){
void left() {
void right() {
It didn't work i still get these errors.
sketch_apr12b.ino: In function 'void loop()':
sketch_apr12b:46: error: 'dforwards' was not declared in this scope
sketch_apr12b:52: error: 'dleft' was not declared in this scope
sketch_apr12b:56: error: 'dright' was not declared in this scope
sketch_apr12b.ino: In function 'void check()':
sketch_apr12b:65: error: return-statement with a value, in function returning 'void'
sketch_apr12b.ino: In function 'void decision()':
sketch_apr12b:69: error: 'servo_left' was not declared in this scope
sketch_apr12b:79: error: 'dforwards' was not declared in this scope
sketch_apr12b:83: error: 'dleft' was not declared in this scope
sketch_apr12b:86: error: 'dright' was not declared in this scope
sketch_apr12b:88: error: return-statement with a value, in function returning 'void'
sketch_apr12b.ino: At global scope:
sketch_apr12b:93: error: variable or field 'servo_left' declared void
sketch_apr12b:93: error: expected primary-expression before '{' token
You are missing a closing parenthesis here:
void servo_left({
  servo.write(50);
// it should be
void servo_left() {
Ok, I fixed that.
#include <Wire.h>
#include <Servo.h>
// Define Pins Here
int ping1;
int ping2;
int ping3;
int ping4;
char pingdecision;
int pingdec;
#define ECHO_PIN 11
Servo myservo;
	lcd.init();
	lcd.backlight();
	check();
	if (pingdec == 1) {
		lcd.setCursor(0,0);
		decision();
			case 1: // If Decision Returns Forwards Move Forwards
					forwards();
					lcd.setCursor(0,1);
			case 2:
				left();
			case 3:
				right();
                        default:
else{
 forwards();
void check(){
if (ping1 < 40){
  pingdec = 1;
else{
 pingdec = 0;
	return pingdec;
void decision() {
	servo_left();
	delay(100);
	servo_center();
	delay(100);
	servo_right();
	delay(100);
		pingdecision = 1;
		pingdecision = 2;
	else {
		pingdecision = 3;
void servo_left({
  servo.write(50);
  servo.write(75);
void servo_right(){
  servo.write(100);
void forwards() {
void backwards(){
void left() {
void right() {
I Get These Errors Now.
sketch_apr12b:81: error: return-statement with a value, in function returning 'void'
sketch_apr12b:105: error: expected unqualified-id before 'return'
sketch_apr12b:106: error: expected declaration before '}' token
The Auto Format tool is very useful in both making code readable, and detecting an uneven number of braces:
Auto Format Cancelled: Too many right curly braces.
else {
		pingdecision = 3;
}                   <<<< this one is extra?
You are also attempting to return a value in a function you have declared as void. A void function isn't expecting to return a value. You are trying to return pingdec which is already global.
A good way to avoid mismatched brackets is to always type them out at the start. For example when I start a for statement I often type the following:
for()
Then I hit ctrl-t for formatting, then I go back and put in code.
