I get this error when I do the verification
DragonCon2012.cpp: In function 'void setup()':
DragonCon2012.pde:-1: error: 'class Button' has no member named 'setHoldDelay'
DragonCon2012.pde:-1: error: a function-definition is not allowed here before '{' token
DragonCon2012.pde:-1: error: expected `}' at end of input
//We always have to include the library
//File created for DragonCon 2011
#include "LedControl.h"
#include <Button.h>
// Change these pin numbers as neccessary
char Pin_dataIn = 9; // data in pin
char Pin_clk = 7; // clk pin
char Pin_load = 8; // load pin
char numOfMatrices = 5; // increment this for each 7219 you've got connected.  I imagine this will be 5.
int brightness = 8; // set the brightness of the LEDs.  Use a value between 0 - 15
char screen[40];
char screenSize = 40;
char textBuffer[3][100];
char textBufferSize[3] = {90,51,66};
int pointer = 0;
long nextFrameTime = 0;
int effectType = 0;
int framePointer = 0;
// init led control object
LedControl lc = LedControl(Pin_dataIn,Pin_clk,Pin_load,numOfMatrices);
Button button = Button(4, HIGH);
/* we always wait a bit between updates of the display */
unsigned int delayTime=40;
   The MAX72XX is in power-saving mode on startup,
   we have to do a wakeup call
  for(int index=0;index<lc.getDeviceCount(); index++) {
    lc.shutdown(index,false);
    /* Set the brightness to a medium values */
    lc.setIntensity(index,brightness);
    /* and clear the display */
    lc.clearDisplay(index);
  randomSeed(analogRead(0));
  button.setHoldDelay(3000);
  loadTextBuffers();
  button.listen();
  if(button.onRelease()) {
    effectType++;
    if(effectType > 10) {
      effectType = 0;
    pointer = 0;
    framePointer = 0;
  long current = millis();
  if(current > nextFrameTime) {
   nextFrameTime = current + delayTime;
   switch(effectType) {
    case 0:
      effectThinLine();
    case 1:
       effectRandomPixels();
    case 2:
      effectScanner();
    case 3:
      effectBlinkingEyes();
    case 4:
      effectTextScroll(0);
    case 5:
      effectTextScroll(1);
    case 6:
      effectTextScroll(2);
    case 7:
      effectArrows();
    case 8:
      effectECG();
    case 9:
      effectScannerHorizontal();
    default:
      effectBlank();
   display();
void display() {
  unsigned char matrixID = 0;
  // screen now holds the updated values
  // write to the matrix
  for(unsigned char i = 0; i < numOfMatrices; i++) {
    for(int j = 0; j < 8; j++) {
      int k = j;
       k += 1;
      if(k > 7) {
        k = 0;
      char matrixID = 4 - i;
      //matrixID = 0;
      char bufferData = screen[((7-k)+(i*8))];
      char rowData = (bufferData >> 1) | (bufferData << 7);
      lc.setRow(matrixID,j,rowData);
  for(unsigned char i = 0; i < screenSize; i++) {
   matrixID = floor(i/8);
    lc.setColumn(matrixID,i,screen[i]);
    for(unsigned char j = 0; j < 8; j++) {
      //matrixID = 0;
      lc.setColumn(matrixID,j,screen[(j+(i*8))]);
void scrollFromRight(int bufferNum) {
int offset = screenSize - pointer;
    screen[i] = getBufferData(bufferNum, i-offset);
void scrollFromLeft(int bufferNum) {
int offset = (0-textBufferSize[bufferNum]) + pointer;
void staticCenter(int bufferNum) {
  int offset = round((screenSize - textBufferSize[bufferNum]) / 2);
char getBufferData(int bufferNum, int pos) {
    char tmp;
    if((pos >= 0) && ((pos) < textBufferSize[bufferNum])) {
      return textBuffer[bufferNum][pos];
      return B00000000;
void effectThinLine() {
  for(int i = 0; i < 40; i++) {
    screen[i] = B00011000;
void effectRandomPixels() {
    screen[i] = random(256);
void effectScanner() {
    screen[i] = B00000000;
  int tmpPointer = framePointer;
  if(framePointer > 37) {
    tmpPointer = 37 - (framePointer - 37);
  for(int i = tmpPointer; i < (tmpPointer+3); i++) {
    screen[i] = B11111111;
  framePointer++;
  if(framePointer > 73) {
    framePointer = 0;
void effectScannerHorizontal() {
    if(framePointer > 6) {
        tmpPointer = 6 - (framePointer - 6);
    screen[i] = B10000000 >> (tmpPointer + 1);
  display();
  delay(50);
  framePointer++;
  if(framePointer > 11) {
    framePointer = 0;
void effectBlank() {
void effectTextScroll(char bufferNum) {
   pointer += 1;
   if(pointer > (textBufferSize[bufferNum] + screenSize)) {
     pointer = 0;
   scrollFromRight(bufferNum);
void effectBlinkingEyes() {
  if(random(50) == 0) {
There's more than one Button library - think you simply have the wrong one (namely from Arduino playground rather than the more complex one from carlynorama's)
and how do I find the right one?
I found it, and now work, thank you so much
Indeed, google is handy isn't it?
