How do I add an ISR to timer1 in setup() without interfering with Serial.println()?
debug.log(F("Setup() complete...")); is effectively Serial.println("Setup() complete...");
I am seeing the following in the serial monitor where output of "Setup() complete..." is getting cut off mid way.
Initializing SD card...done!
[WiFiEsp] Initializing ESP module
[WiFiEsp] Initilization successful - 1.1.1
From SD card SSID = Telstra6A61B7, KEY = 0AC9703D29
Attempting to connect to WPA SSID: Telstra6A61B7
[WiFiEsp] Connected to Telstra6A61B7
You're connected to the network with IP address: 10.0.0.79
[WiFiEsp] Server started on port 80
station1
probe:
allowed_dry_time:0
probe_threshold_value:0
probe_auto:
auto_run_time:0
suspend:
00:00-1(done),02:00-1(done),04:00-1(done),06:00-1(done),08:00-1(done),10:00-1(done),12:00-1(done),14:00-1(done),16:00-1(not done),18:00-1(not done),20:00-1(not done),22:00-1(not done)
station2
probe:installed
allowed_dry_time:10
probe_threshold_value:1500
probe_auto:yes
auto_run_time:1
suspend:
00:00-10(done)
station3
probe:
allowed_dry_time:0
probe_auto:
auto_run_time:0
suspend:
00:00-10(done)
station4
probe:
allowed_dry_time:0
probe_auto:
auto_run_time:0
suspend:
station5
probe:
allowed_dry_time:0
probe_auto:
auto_run_time:0
suspend:
00:00-10(done)
station6
probe:
allowed_dry_time:0
probe_auto:
auto_run_time:0
suspend:
00:00-10(done)
station7
probe:
allowed_dry_time:0
probe_auto:
auto_run_time:0
suspend:
00:00-10(done)
station8
probe:
allowed_dry_time:0
probe_auto:
auto_run_time:0
suspend:
Synchronising RTC from '0.uk.pool.ntp.org'...14/11 15:25...done!
Set
//* Runs at 1 minute intervals
bool g_bNewDayFlag = false;
bool g_bISRTriggered = false;
void On1MinTimer()
noInterrupts();
rtc.readClock();
g_bNewDayFlag = rtc.getHours() == 0;
// Then iterate through all the programs, for all stations and for today's date, and we need to run any of them based on the current time.
program.run();
// A new day has started so we need to read the program.txt and get the irrigations times for the new date so read in the program for each station for the new date.
if (g_bNewDayFlag)
debug.init();
debug.dumpSaved();
debug.log(F("########################################"));
debug.log(F("NEW DAY"));
debug.log(F("--------"));
debug.log(F("Reading program.txt!"));
if (!program.read())
debug.logRuntimeError(F("IrrigationController.ino"), __LINE__);
g_nWeekDayNum++;
if (g_nWeekDayNum == 7)
OnWeeklyTimer();
g_nWeekDayNum == 1;
g_nMinNum++;
if (g_nMinNum == 10)
OnAlarmsTimer();
g_nMinNum == 0;
interrupts();
void isrFunction()
g_bISRTriggered = true;
// Do all the setup tasks.
program.begin();
// Wait for serial port to connect - needed for native USB port only
delay(10);
if (initSD())
debug.init();
serialHC05.begin(9600);
if (WifiServer.begin() && program.read())
program.begin();
debug.logRuntimeError(F("IrrigationController.cpp"), __LINE__);
WifiServer.synchClock();
rtc.readClock();
timeLastAlarms.set(rtc.getHours(), rtc.getMinutes(), rtc.getSeconds());
[b]noInterrupts();
Timer1.initialize(600000L);
Timer1.attachInterrupt(isrFunction);
interrupts();
debug.log(F("Setup() complete..."));[/b]
