I got a error message.
Hi all,
I try to use 2 UNO board + 2 nRF24L01 + DS18B20
I refer to the Tiny code.
Source:
I have installed the following libraries
DallasTemperature
mirf85
Narcoleptic
OneWire
RF24
SPI85
verify got error message:
digitalWrite(ONE_WIRE_GND, LOW); // set GND pin low
2014-09-10_104607 by guccltaipei, on Flickr
Please post your code here;
Please use code tags.. See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png or pdf?
You can do all that on the forum without having to post it off site.
If posting is too big then attach it useing "Additional Options" tag.
Tom..... :slight_smile:
Here is my reference code
digitalWrite(ONE_WIRE_GND, LOW); // set GND pin low <--------Validation error stopped at this line
#include <SPI85.h>
#include <Mirf85.h>
#include <MirfHardwareSpiDriver85.h>
#include <OneWire.h> // http://www.pjrc.com/teensy/arduino_libraries/OneWire.zip
#include <DallasTemperature.h> // http://download.milesburton.com/Arduino/MaximTemperature/DallasTemperature_LATEST.zip
#include <Narcoleptic.h> // https://code.google.com/p/narcoleptic/
#define myNodeID 1        // node ID
#define ONE_WIRE_BUS 10   // DS18B20 Temperature sensor is connected on D10
#define ONE_WIRE_POWER 9  // DS18B20 Power pin is connected on D9
OneWire oneWire(ONE_WIRE_BUS); // Setup a oneWire instance
DallasTemperature sensors(&oneWire); // Pass our oneWire reference to Dallas Temperature
//Data Structure to be sent
 typedef struct {
          byte nodeID;  // nodeID
    	  int temp;	// Temperature reading
  	  int supplyV;	// Supply voltage
 } Payload;
 Payload tinytx;
// Read current supply voltage
 long readVcc() {
   bitClear(PRR, PRADC); ADCSRA |= bit(ADEN); // Enable the ADC
   long result;
   // Read 1.1V reference against Vcc
   #if defined(__AVR_ATtiny84__)
    ADMUX = _BV(MUX5) | _BV(MUX0); // For ATtiny84
   #else
    ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);  // For ATmega328
   #endif
   delay(2); // Wait for Vref to settle
   ADCSRA |= _BV(ADSC); // Convert
   while (bit_is_set(ADCSRA,ADSC));
   result = ADCL;
   result |= ADCH<<8;
   result = 1126400L / result; // Back-calculate Vcc in mV
   ADCSRA &= ~ bit(ADEN); bitSet(PRR, PRADC); // Disable the ADC to save power
   return result;
  Mirf.cePin = 8;  // CE on D8
  Mirf.csnPin = 7; // CSN on D7
  Mirf.spi = &MirfHardwareSpi;
  Mirf.init();
  Mirf.channel = 0x5a; // Channel number = 90. Range 0 - 127 or 0 - 84 in the US.
  Mirf.rfsetup = 0x27; // 250kpbs full power
  byte RADDR[] = {0xe2, 0xf0, 0xf0, 0xf0, 0xf0};
  byte TADDR[] = {0xe3, 0xf0, 0xf0, 0xf0, 0xf0};
  Mirf.setRADDR(RADDR);
  Mirf.setTADDR(TADDR);
  Mirf.config();
  // Enable dynamic payload
 Mirf.configRegister( FEATURE, 1<<EN_DPL );
 Mirf.configRegister( DYNPD, 1<<DPL_P0 | 1<<DPL_P1 | 1<<DPL_P2 | 1<<DPL_P3 | 1<<DPL_P4 | 1<<DPL_P5 );
  pinMode(ONE_WIRE_POWER, OUTPUT); // set power pin for DS18B20 to output
  PRR = bit(PRTIM1); // only keep timer 0 going
  digitalWrite(ONE_WIRE_POWER, HIGH); // turn DS18B20 sensor on
  delay(5); // Allow 5ms for the sensor to be ready
  tinytx.nodeID = myNodeID;
  sensors.begin(); //start up temp sensor
  sensors.requestTemperatures(); // Get the temperature
  tinytx.temp=(sensors.getTempCByIndex(0)*100); // Read first sensor and convert to integer, reversed at receiving end
  digitalWrite(ONE_WIRE_POWER, LOW); // turn DS18B20 off
  tinytx.supplyV = readVcc(); // Get supply voltage
  Mirf.payload = sizeof (tinytx);
  Mirf.send((byte *) &tinytx);
  while( Mirf.isSending() ) {
    delay(1);
 Narcoleptic.delay(60000); // enter low power mode for 60 seconds, valid range 16-32000 ms with standard Narcoleptic lib
                            // change variable for delay from int to unsigned int in Narcoleptic.cpp and Narcoleptic.h
                            // to extend range up to 65000 ms
ONE_WIRE_GND
is defined where?
Oh~ thank you
but i add #define ONE_WIRE_GND 9
got other errors and no mark in code
got other errors
So? Fix the problems.
Do NOT post pictures of errors! Post the damned text.
You can't have both power(HIGH) and ground(GND) on the same pin.
Why put it on a digital pin and not on one of the three GND pins or the one on the ICSP header?
Sure you can...he just did! Lesson learned: You can't put blue smoke back into the part that caused it.
