i got expected unqualified-id before 'if" can someone help me
here is my code and sorry i am a beginner and i am still learning so here is my code
#include <IRremote.h>
int IRpin = 11;
IRrecv irrecv(IRpin);
decode_results results;
int Relay1=4; // Initializing the pins for Relay
int Relay2=5;
int Relay3=6;
int Relay4=7;
int Relay5=12;
int Relay6=9;
int Relay7=10;
int Relay8=13;
int val1=0; // Inializing the variable for storing the last status of Relay_pins
int val2=0;
int val3=0;
int val4=0;
int val5=0;
int val7=0;
int val8=0;
int val9=0;
int val10=0;
irrecv.enableIRIn(); // Start the receiver
pinMode(Relay1,OUTPUT);
pinMode(Relay2,OUTPUT);
pinMode(Relay3,OUTPUT);
pinMode(Relay4,OUTPUT);
pinMode(Relay5,OUTPUT);
pinMode(Relay6,OUTPUT);
pinMode(Relay7,OUTPUT);
pinMode(Relay8,OUTPUT);
digitalWrite(Relay1,HIGH);
digitalWrite(Relay2,HIGH);
digitalWrite(Relay3,HIGH);
digitalWrite(Relay4,HIGH);
digitalWrite(Relay5,HIGH);
digitalWrite(Relay6,HIGH);
digitalWrite(Relay7,HIGH);
digitalWrite(Relay8,HIGH);
if (irrecv.decode(&results))
Serial.println(results.value); // Print the Serial 'results.value'
delay(10);
irrecv.resume(); // Receive the next value
if(results.value==33444015)
val1=digitalRead(Relay1);
if(val1==0)
val1=1;
delay(100);
digitalWrite(Relay1,LOW);
val1=0;
delay(100);
if(results.value==33478695)
val1=digitalRead(Relay2);
if(val2==0)
val2=1;
delay(100);
digitalWrite(Relay2,LOW);
val2=0;
delay(100);
if(results.value==33486855)
val1=digitalRead(Relay3);
if(val3==0)
val3=1;
delay(100);
digitalWrite(Relay3,LOW);
val3=0;
delay(100);
if(results.value==33435855)
val4=digitalRead(Relay4);
if(val4==0)
val4=1;
delay(100);
digitalWrite(Relay4,LOW);
val4=0;
delay(100);
if(results.value==33468495)
val1=digitalRead(Relay5);
if(val5==0)
val5=1;
delay(100);
digitalWrite(Relay5,LOW);
val5=0;
delay(100);
if(results.value==33423615)
val7=digitalRead(Relay6);
if(val7==0)
val7=1;
delay(100);
digitalWrite(Relay6,LOW);
val8=0;
delay(100);
if(results.value==33452175)
val9=digitalRead(Relay7);
if(val9==0)
val8=1;
delay(100);
digitalWrite(Relay7,LOW);
val8=0;
delay(100);
if(results.value==33484815)
val9=digitalRead(Relay8);
if(val9==0)
val9=1;
delay(100);
digitalWrite(Relay8,LOW);
val9=0;
delay(100);
if(results.value==33441975)
digitalWrite(Relay1,0);
digitalWrite(Relay2,0);
digitalWrite(Relay3,0);
digitalWrite(Relay4,0);
digitalWrite(Relay5,0);
digitalWrite(Relay6,0);
digitalWrite(Relay7,0);
digitalWrite(Relay8,0);
if(results.value ==33454215)
digitalWrite(Relay1,1);
digitalWrite(Relay2,1);
digitalWrite(Relay3,1);
digitalWrite(Relay4,1);
digitalWrite(Relay5,1);
digitalWrite(Relay6,1);
digitalWrite(Relay7,1);
digitalWrite(Relay8,1);
Format your code using Auto Format in the IDE then you will see this portion of it starts on the left margin which means that the code is not in a function
if (results.value == 33454215)
  digitalWrite(Relay1, 1);
  digitalWrite(Relay2, 1);
  digitalWrite(Relay3, 1);
  digitalWrite(Relay4, 1);
  digitalWrite(Relay5, 1);
  digitalWrite(Relay6, 1);
  digitalWrite(Relay7, 1);
  digitalWrite(Relay8, 1);
Where does the loop() function end ?
Also... When you are tempted to use numbers in the naming of variables, it is time to learn about arrays. Arrays would make the code much shorter.
