i got the error of (1)expected unqualified-id before 'volatile'
#include <TimerOne.h>
#include <avr/sleep.h>
#include <avr/interrupt.h>
#include <SoftwareSerial.h>
volatile float digitalValue;
void sleep()
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
pinMode(2,OUTPUT);
Timer.intialize(1000000);
Timer.attachInterrupt(ADC);
noInterrupts();
sleep_enable();
sleep_cpu();
interrupts();
sleep_disable();
void ADC()
if(A0 != 0)
pinMode(A0,INPUT);
float digitalValue;
float sensorPin=A0;
digitalValue = analogRead(sensorPin);
Serial.print("digital value = ");
Serial.println(digitalValue);
Are you sure that you have posted the correct code ?
The errors that I get are to do with the fact that the Timer object has not been declared along with the fact that the ADC() function has no return type and this
is surely wrong too
You've got two variables called digitalValue.
Please remember to use code tags when posting code
  if(A0 != 0)
There is no Arduino for which A0 is defined as 0.
