I am new to Arduino, and i am following the kit book guidance, and come to Chapter 5, Servo Motor.
I follow the code is okay, but when I try to understand and compare the codes with previous chapter i have below quesion, Could anyone please give guidance to me please.
I don't understand why don't use previous chapter code: "analogWrite"????
Then I try to change as below, the motor moves but with shivering, why???????????
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. If your browser doesn't show the posting toolbar then you can just manually add the code tags: [code]``[color=blue]// your code is here[/color]``[/code]
Using code tags and other important information is explained in the How to use this forum post. Please read it.
Please always do a Tools > Auto Format on your code before posting it. This will make it easier for you to spot bugs and make it easier for us to read. If you're using the Arduino Web Editor you will not have access to this useful tool but it's still unacceptable to post poorly formatted code. I recommend you to use the standard IDE instead.
totohk:
analogWrite() can only be used on pins that support hardware PWM. The Servo library allows you to use non-PWM pins so that you can control more servos. I believe the reason they start with analogWrite() is to give you a more basic understanding of how servos work.
totohk:
Thank you.
I have briefly read the "How to use this forum post." as you mentioned, I will try to follow the rules here. This forum is quite different from my experiences, but I will try to follow, avoid bring inconvenience here.
#include <Servo.h>
Servo myservo;
int const inputpin = A0;
int inputvalue;
int angle;
pinMode(9,OUTPUT);
//*********************why i can use this as output??with strange result??
//myservo.attach(9);
inputvalue = analogRead(inputpin);
Serial.print("Input pot value: ");
Serial.print(inputvalue);
angle = map(inputvalue,6,1017,10,170);
Serial.print(", angle: ");
Serial.println(angle);
analogWrite(9,angle);
//myservo.write(angle);
delay(15);
spycatcher2k:
analogWrite outputs a PWM signal - pulse width modulation
Servos work on a PPM signal - pulse position modulation
They are similar, but different.
No, servos also work on PWM, it's just that the frequency and duty-cycle reailution of analogWrite PWM is unsuitable for driving standard RC servos.
(PPM is only used in the transmitter to receiver multiplexed.stream)
