When I open the arduino IDE it donsen´t work
This is what I get in the powershell window:
PS C:\Users\aaque\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE".
Starting backend process. PID: 6052
Using browser-only version of superagent in non-browser environment
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
root INFO Configuration directory URI: 'file:///c%3A/Users/aaque/.theia'
root ERROR (node:6052) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
root INFO Theia app listening on http://localhost:52546.
root WARN The local plugin referenced by local-dir:/c%3A/Users/aaque/.arduinoIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:/c%3A/Users/aaque/.arduinoIDE/extensions does not exist.
root WARN The local plugin referenced by local-dir:C:\Users\aaque\.arduinoProIDE\plugins does not exist.
root INFO PluginTheiaDirectoryHandler: accepting plugin with path
root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@0.3.10" with engines:
root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.1" with engines:
root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
root INFO Deploying backend plugin "cortex-debug@0.3.10" from "C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension"
root INFO Deploying backend plugin "vscode-arduino-tools@0.0.2-beta.1" from "C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle"
root INFO Deploying backend plugin "cpp@1.52.1" from "C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension"
root INFO Deploying backend plugin "json@1.46.1" from "C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension"
root INFO Deploying backend plugin "json-language-features@1.46.1" from "C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain"
root INFO Deploy plugins list took: 176.5 ms
root WARN Backend ConfigServiceImpl.onStart is slow, took: 219.6 ms
daemon INFO Starting daemon from C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
daemon INFO Using config file: c:\Users\aaque\.arduinoIDE\arduino-cli.yaml
daemon INFO arduino-cli.exe version 0.20.2
daemon INFO Executing `arduino-cli daemon`
daemon INFO Setting up Prometheus metrics on :9090/metrics
daemon INFO {"IP":"127.0.0.1","Port":"52547"}
daemon INFO Daemon is running.
daemon INFO Checking if CLI is Bundled into the IDE
daemon INFO Adding libraries dir [dir: C:\Users\aaque\OneDrive\Documentos\Arduino\libraries, location: user]
daemon INFO URL: https://downloads.arduino.cc/packages/package_index.json
daemon INFO Updating index [url: https://downloads.arduino.cc/packages/package_index.json]
root INFO Git askpass helper is listening on http://127.0.0.1:52558.
root ERROR Error: Git installation not found.
at C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\find-git-exec\lib\find-git-exec.js:69:69
at async DefaultGitInit.init (C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\theia\git\git-init.js:22:49)
root WARN Frontend CommonFrontendContribution.configure is slow, took: 450.8 ms
root WARN Failed to resolve module: @types/body-parser
root WARN Failed to resolve module: @types/cookie
root WARN Failed to resolve module: @types/dompurify
root WARN Failed to resolve module: @types/express
root WARN Failed to resolve module: @types/fs-extra
root WARN Failed to resolve module: @types/lodash.debounce
root WARN Failed to resolve module: @types/lodash.throttle
root WARN Failed to resolve module: @types/react
root WARN Failed to resolve module: @types/react-dom
root WARN Failed to resolve module: @types/react-virtualized
root WARN Failed to resolve module: @types/route-parser
root WARN Failed to resolve module: @types/safer-buffer
root WARN Failed to resolve module: @types/ws
root WARN Failed to resolve module: @types/yargs
root WARN Failed to resolve module: @theia/monaco
root WARN Failed to resolve module: @theia/editor
root WARN Failed to resolve module: @types/multer
root WARN Failed to resolve module: @types/rimraf
root WARN Failed to resolve module: @types/tar-fs
root WARN Failed to resolve module: @types/uuid
root WARN Failed to resolve module: @theia/navigator
root WARN Failed to resolve module: @types/p-queue
root WARN Failed to resolve module: @theia/preferences
root WARN Failed to resolve module: @theia/editor-preview
root WARN Failed to resolve module: @theia/keymaps
root WARN Failed to resolve module: @theia/messages
root WARN Failed to resolve module: @types/diff
root WARN Failed to resolve module: @types/markdown-it
root WARN Failed to resolve module: @types/mime
root WARN Failed to resolve module: @types/request
root WARN Failed to resolve module: @types/atob
root WARN Failed to resolve module: @types/auth0-js
root WARN Failed to resolve module: @types/btoa
root WARN Failed to resolve module: @types/dateformat
root WARN Failed to resolve module: @types/deepmerge
root WARN Failed to resolve module: @types/glob
root WARN Failed to resolve module: @types/google-protobuf
root WARN Failed to resolve module: @types/js-yaml
root WARN Failed to resolve module: @types/keytar
root WARN Failed to resolve module: @types/ncp
root WARN Failed to resolve module: @types/node-fetch
root WARN Failed to resolve module: @types/ps-tree
root WARN Failed to resolve module: @types/react-select
root WARN Failed to resolve module: @types/react-tabs
root WARN Failed to resolve module: @types/temp
root WARN Failed to resolve module: @types/which
root INFO Updating index: package_index.json completed.
root INFO Updating index: package_index.json.sig completed.
daemon INFO Checking signature [error: opening signature file: open C:\Users\aaque\AppData\Local\Temp\667560979.sig: The system cannot find the file specified., index: C:\Users\aaque\AppData\Local\Temp\667560979, signaturefile: C:\Users\aaque\AppData\Local\Temp\667560979.sig]
daemon INFO Updating libraries index
root WARN Frontend keybindings.onStart is slow, took: 106.5 ms
root INFO Updating index: library_index.json.gz completed.
root INFO Updating index: library_index.json.sig completed.
root ERROR DefaultJsonSchemaContribution.registerSchemas is taking more than 500.0 ms, new schemas are ignored.
daemon INFO Checking signature [index: C:\Users\aaque\AppData\Local\Arduino15\package_index.json, signaturefile: C:\Users\aaque\AppData\Local\Arduino15\package_index.json.sig, trusted: true]
daemon INFO Loading hardware from: C:\Users\aaque\AppData\Local\Arduino15\packages
daemon INFO Loading package arduino from: C:\Users\aaque\AppData\Local\Arduino15\packages\arduino\hardware
daemon INFO Checking signature [error: opening signature file: open C:\Users\aaque\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\installed.json.sig: The system cannot find the file specified., index: C:\Users\aaque\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\installed.json, signaturefile: C:\Users\aaque\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\installed.json.sig]
daemon INFO Adding monitor tool [protocol: serial, tool: builtin:serial-monitor]
daemon INFO Loaded platform [platform: {ID:"arduino:avr",Installed:"1.8.6",Latest:"1.8.6",Name:"Arduino AVR Boards"}]
daemon INFO Checking existence of 'tools' path: C:\Users\aaque\AppData\Local\Arduino15\packages\arduino\tools
daemon INFO Loading tools from dir: C:\Users\aaque\AppData\Local\Arduino15\packages\arduino\tools
daemon INFO Loaded tool [tool: Version: 1.3.0 Systems: [OS: i686-linux-gnu, OS: x86_64-linux-gnu, OS: arm-linux-gnueabihf, OS: aarch64-linux-gnu, OS: i386-apple-darwin11, OS: i686-mingw32]]
daemon INFO Loaded tool [tool: Version: 7.3.0-atmel3.6.1-arduino7 Systems: [OS: arm-linux-gnueabihf, OS: aarch64-linux-gnu, OS: x86_64-apple-darwin14, OS: i686-mingw32, OS: i686-linux-gnu, OS: x86_64-linux-gnu]]
daemon INFO Loaded tool [tool: Version: 6.3.0-arduino17 Systems: [OS: arm-linux-gnueabihf, OS: aarch64-linux-gnu, OS: x86_64-apple-darwin12, OS: x86_64-linux-gnu, OS: i686-linux-gnu, OS: i686-mingw32]]
daemon INFO Loading package builtin from: C:\Users\aaque\AppData\Local\Arduino15\packages\builtin
daemon INFO Checking existence of 'tools' path: C:\Users\aaque\AppData\Local\Arduino15\packages\builtin\tools
daemon INFO Loading tools from dir: C:\Users\aaque\AppData\Local\Arduino15\packages\builtin\tools
daemon INFO Loaded tool [tool: Version: 5.8-arduino11 Systems: [OS: i686-pc-linux-gnu, OS: x86_64-pc-linux-gnu, OS: i686-mingw32, OS: x86_64-apple-darwin, OS: arm-linux-gnueabihf, OS: aarch64-linux-gnu]]
daemon INFO Loaded tool [tool: Version: 0.1.2 Systems: [OS: i686-pc-linux-gnu, OS: x86_64-pc-linux-gnu, OS: i686-mingw32, OS: x86_64-mingw32, OS: x86_64-apple-darwin, OS: arm64-apple-darwin, OS: arm-linux-gnueabihf, OS: arm64-linux-gnueabihf]]
daemon INFO Loaded tool [tool: Version: 1.0.2]
daemon INFO Loaded tool [tool: Version: 1.0.6]
daemon INFO Loaded tool [tool: Version: 1.0.8 Systems: [OS: i686-pc-linux-gnu, OS: x86_64-pc-linux-gnu, OS: i686-mingw32, OS: x86_64-mingw32, OS: x86_64-apple-darwin, OS: arm64-apple-darwin, OS: arm-linux-gnueabihf, OS: arm64-linux-gnueabihf]]
daemon INFO Loaded tool [tool: Version: 1.0.9 Systems: [OS: i686-pc-linux-gnu, OS: x86_64-pc-linux-gnu, OS: i686-mingw32, OS: x86_64-mingw32, OS: x86_64-apple-darwin, OS: arm64-apple-darwin, OS: arm-linux-gnueabihf, OS: arm64-linux-gnueabihf]]
daemon INFO Loaded tool [tool: Version: 1.3.1]
daemon INFO Loaded tool [tool: Version: 1.3.2]
daemon INFO Loaded tool [tool: Version: 1.4.0 Systems: [OS: i686-pc-linux-gnu, OS: x86_64-pc-linux-gnu, OS: i686-mingw32, OS: x86_64-mingw32, OS: x86_64-apple-darwin, OS: arm64-apple-darwin, OS: arm-linux-gnueabihf, OS: arm64-linux-gnueabihf]]
daemon INFO Loaded tool [tool: Version: 0.10.0]
daemon INFO Loaded tool [tool: Version: 0.11.0]
daemon INFO Loaded tool [tool: Version: 0.13.0 Systems: [OS: i686-pc-linux-gnu, OS: x86_64-pc-linux-gnu, OS: i686-mingw32, OS: x86_64-mingw32, OS: x86_64-apple-darwin, OS: arm-linux-gnueabihf, OS: arm64-linux-gnueabihf]]
daemon INFO Loaded tool [tool: Version: 0.14.1 Systems: [OS: i686-pc-linux-gnu, OS: x86_64-pc-linux-gnu, OS: i686-mingw32, OS: x86_64-mingw32, OS: x86_64-apple-darwin, OS: arm64-apple-darwin, OS: arm-linux-gnueabihf, OS: arm64-linux-gnueabihf]]
daemon INFO Loaded tool [tool: Version: 0.9.1]
daemon INFO Adding libraries dir [dir: C:\Users\aaque\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries, location: platform]
daemon INFO starting discovery builtin:mdns-discovery process
daemon INFO starting discovery builtin:serial-discovery process
root ERROR Request repositories failed with error: Git could not be found at the expected path: 'C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\dugite-no-gpl\git\cmd\git.exe'. This might be a problem with how the application is packaged, so confirm this folder hasn't been removed when packaging.
root WARN Frontend EditorNavigationContribution.onStart is slow, took: 5238.7 ms
root WARN Frontend WorkspaceService.onStart is slow, took: 136.3 ms
root INFO Changed application state from 'init' to 'started_contributions'.
root INFO Changed application state from 'started_contributions' to 'attached_shell'.
root INFO >>> Restoring the layout state...
daemon INFO started discovery builtin:mdns-discovery process
daemon INFO sending command HELLO 1 "arduino-cli 0.20.2" to discovery builtin:mdns-discovery
daemon INFO started discovery builtin:serial-discovery process
daemon INFO sending command HELLO 1 "arduino-cli 0.20.2" to discovery builtin:serial-discovery
daemon INFO from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
daemon INFO from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
daemon INFO sending command START_SYNC to discovery builtin:serial-discovery
daemon INFO sending command START_SYNC to discovery builtin:mdns-discovery
daemon INFO from discovery builtin:serial-discovery received message type: start_sync, message: OK
daemon INFO from discovery builtin:mdns-discovery received message type: start_sync, message: OK
root INFO [c12ac369-61dc-48aa-a482-3f4696338876] Waiting for backend deployment took: 269.8 ms [Finished 10.052 s after frontend start]
root INFO [c12ac369-61dc-48aa-a482-3f4696338876] Sync of 5 plugins took: 227.6 ms [Finished 10.280 s after frontend start]
daemon INFO panic: runtime error: invalid memory address or nil pointer dereference
daemon INFO [signal 0xc0000005 code=0x0 addr=0x20 pc=0x11142cc]
daemon INFO goroutine 344 [running]:
daemon INFO github.com/arduino/arduino-cli/commands/lib.getLibraryDependenciesParameter(0xc007c86c20, 0x1, 0x1, 0x1bc5a3e4701f001, 0xffffffffffffffff, 0x0)
daemon INFO /home/build/commands/lib/search.go:99 +0xec
daemon INFO github.com/arduino/arduino-cli/commands/lib.getLibraryParameters(0xc000a11ef0, 0xc00065d830)
daemon INFO /home/build/commands/lib/search.go:83 +0x72
daemon INFO github.com/arduino/arduino-cli/commands/lib.indexLibraryToRPCSearchLibrary(0xc000a140f0, 0x0)
daemon INFO /home/build/commands/lib/search.go:58 +0xd5
daemon INFO github.com/arduino/arduino-cli/commands/lib.searchLibrary(0xc001fcc600, 0xc0002d0880, 0x1)
daemon INFO /home/build/commands/lib/search.go:48 +0x1d3
daemon INFO github.com/arduino/arduino-cli/commands/lib.LibrarySearch(0x15ecd50, 0xc0017edf80, 0xc001fcc600, 0x13f4700, 0x1418d60, 0xc0017edf00)
daemon INFO /home/build/commands/lib/search.go:36 +0x98
daemon INFO github.com/arduino/arduino-cli/commands/daemon.(*ArduinoCoreServerImpl).LibrarySearch(0xc00026f8e0, 0x15ecd50, 0xc0017edf80, 0xc001fcc600, 0xc00026f8e0, 0xc0017edf80, 0xc000f33ba0)
daemon INFO /home/build/commands/daemon/daemon.go:444 +0x46
daemon INFO github.com/arduino/arduino-cli/rpc/cc/arduino/cli/commands/v1._ArduinoCoreService_LibrarySearch_Handler(0x1418d60, 0xc00026f8e0, 0x15ecd50, 0xc0017edf80, 0xc0017d13e0, 0x0, 0x15ecd50, 0xc0017edf80, 0xc0017d9ff0, 0x4)
daemon INFO /home/build/rpc/cc/arduino/cli/commands/v1/commands_grpc.pb.go:1968 +0x224
daemon INFO google.golang.org/grpc.(*Server).processUnaryRPC(0xc000242c40, 0x15f8578, 0xc000084300, 0xc001fda000, 0xc00039c3f0, 0x1bbeb60, 0x0, 0x0, 0x0)
daemon INFO /go/pkg/mod/google.golang.org/grpc@v1.38.0/server.go:1286 +0x52b
daemon INFO google.golang.org/grpc.(*Server).handleStream(0xc000242c40, 0x15f8578, 0xc000084300, 0xc001fda000, 0x0)
daemon INFO /go/pkg/mod/google.golang.org/grpc@v1.38.0/server.go:1609 +0xd0c
daemon INFO google.golang.org/grpc.(*Server).serveStreams.func1.2(0xc000088100, 0xc000242c40, 0x15f8578, 0xc000084300, 0xc001fda000)
daemon INFO /go/pkg/mod/google.golang.org/grpc@v1.38.0/server.go:934 +0xb2
daemon INFO created by google.golang.org/grpc.(*Server).serveStreams.func1
daemon INFO /go/pkg/mod/google.golang.org/grpc@v1.38.0/server.go:932 +0x1fd
root ERROR Uncaught Exception:
root ERROR Error: 14 UNAVAILABLE: read ECONNRESET
at Object.callErrorFromStatus (C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\call.js:31:26)
at Object.onReceiveStatus (C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\client.js:390:49)
at Object.onReceiveStatus (C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\client-interceptors.js:299:181)
at C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\call-stream.js:145:78
at processTicksAndRejections (internal/process/task_queues.js:76:11)
root INFO board watch ended
root ERROR Request search failed with error: 14 UNAVAILABLE: read ECONNRESET
daemon INFO Daemon exited with exit code: 2.
root INFO <<< The layout has been successfully restored.
root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
root INFO [c12ac369-61dc-48aa-a482-3f4696338876][marus25.cortex-debug]: Loaded contributions.
root INFO [c12ac369-61dc-48aa-a482-3f4696338876][arduino.vscode-arduino-tools]: Loaded contributions.
root INFO [c12ac369-61dc-48aa-a482-3f4696338876][vscode.cpp]: Loaded contributions.
root INFO [c12ac369-61dc-48aa-a482-3f4696338876][vscode.json]: Loaded contributions.
root INFO [c12ac369-61dc-48aa-a482-3f4696338876][vscode.json-language-features]: Loaded contributions.
root INFO [c12ac369-61dc-48aa-a482-3f4696338876] Load contributions of 5 plugins took: 137.5 ms [Finished 11.254 s after frontend start]
root WARN Frontend EditorPreviewTreeDecorator.onDidInitializeLayout is slow, took: 138.9 ms
root INFO Finished loading frontend application after 11.352 seconds
root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
root WARN a registered grammar configuration for 'cpp' language is overridden
root INFO [hosted-plugin: 14128] PLUGIN_HOST(14128) starting instance
root INFO [hosted-plugin: 14128] PLUGIN_HOST(14128): PluginManagerExtImpl/init()
root INFO [hosted-plugin: 14128] PLUGIN_HOST(14128): initializing(cortex-debug@0.3.10 with C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 14128] Debugger contribution has been registered: cortex-debug
root INFO [hosted-plugin: 14128] PLUGIN_HOST(14128): initializing(vscode-arduino-tools@0.0.2-beta.1 with C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 14128] PLUGIN_HOST(14128): initializing(cpp@1.52.1 with C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 14128] PLUGIN_HOST(14128): initializing(json@1.46.1 with C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 14128] PLUGIN_HOST(14128): initializing(json-language-features@1.46.1 with C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 14128] PLUGIN_HOST(14128): PluginManagerExtImpl/loadPlugin(C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
root INFO [hosted-plugin: 14128] PLUGIN_HOST(14128): PluginManagerExtImpl/loadPlugin(C:\Users\aaque\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
root INFO Changed application state from 'initialized_layout' to 'ready'.
root INFO [c12ac369-61dc-48aa-a482-3f4696338876][marus25.cortex-debug]: Started plugin.
root INFO [c12ac369-61dc-48aa-a482-3f4696338876][arduino.vscode-arduino-tools]: Started plugin.
root INFO [c12ac369-61dc-48aa-a482-3f4696338876][vscode.cpp]: Started plugin.
root INFO [c12ac369-61dc-48aa-a482-3f4696338876][vscode.json]: Started plugin.
root INFO [c12ac369-61dc-48aa-a482-3f4696338876][vscode.json-language-features]: Started plugin.
root INFO [c12ac369-61dc-48aa-a482-3f4696338876] Start of 5 plugins took: 919.1 ms [Finished 12.185 s after frontend start]
root ERROR Request loadSketch failed with error: 14 UNAVAILABLE: No connection established
root ERROR Error: Request 'loadSketch' failed
at Proxy.<anonymous> (file:///C:/Users/aaque/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:58993:35)
at ArduinoFrontendContribution.openSketchFiles (file:///C:/Users/aaque/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/vendors-node_modules_arduino-ide-extension_lib_browser_arduino-ide-frontend-module_js-node_mo-f364c9.bundle.js:7079:53)
at Object.execute (file:///C:/Users/aaque/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/vendors-node_modules_arduino-ide-extension_lib_browser_arduino-ide-frontend-module_js-node_mo-f364c9.bundle.js:7047:22)
at CommandRegistry.executeCommand (file:///C:/Users/aaque/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:55950:42)
at async FrontendApplication.initializeLayout (file:///C:/Users/aaque/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/vendors-node_modules_arduino-ide-extension_lib_browser_arduino-ide-frontend-module_js-node_mo-f364c9.bundle.js:18960:17)
at async FrontendApplication.start (file:///C:/Users/aaque/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:35384:9)
