i have a problem using timer 1 fast pwm prescaler 64 tinkercad
Why not use setup() and loop(), not main?
No need to constantly update OCR1A, set it once.
Its wise to reset TCNT1 to zero once you've changed the OCR1x registers.
I think it works as is except pin 10 isn't changing - change
        PORTB ^= ( 1<< PB2 );
to
        PORTB ^= PB2 ;
to fix that.
, not PB2 to fix that.
Not sure what PB2 is, I suspect its a bit number not a bitmask
