I have a problem with image classification esp32-cam project with edge impluse studio, can you help me?
here is my basic_image_classification code :
/* Includes ---------------------------------------------------------------- */
#include <Arduino.h>
#include <WiFi.h>
/* Modify the following line according to your project name
Do not forget to import the library using "Sketch">"Include Library">"Add .ZIP Library..."
#include <fruitsclassification_inferencing.h>
#include "esp_http_server.h"
#include "img_converters.h"
#include "image_util.h"
#include "esp_camera.h"
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT // Has PSRAM
//#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_PSRAM // Has PSRAM
//#define CAMERA_MODEL_M5STACK_V2_PSRAM // M5Camera version B Has PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_ESP32CAM // No PSRAM
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
//#define CAMERA_MODEL_TTGO_T_JOURNAL // No PSRAM
#include "camera_pins.h"
#define PART_BOUNDARY "123456789000000000000987654321"
static const char* _STREAM_CONTENT_TYPE = "multipart/x-mixed-replace;boundary=" PART_BOUNDARY;
static const char* _STREAM_BOUNDARY = "\r\n--" PART_BOUNDARY "\r\n";
static const char* _STREAM_PART = "Content-Type: image/jpeg\r\nContent-Length: %u\r\n\r\n";
httpd_handle_t camera_httpd = NULL;
httpd_handle_t stream_httpd = NULL;
const char* ssid = "809";
const char* password = "0915127188";
dl_matrix3du_t *resized_matrix = NULL;
size_t out_len = EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_HEIGHT;
ei_impulse_result_t result = {0};
Serial.setDebugOutput(true);
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
config.frame_size = FRAMESIZE_240X240;
config.jpeg_quality = 12;
config.fb_count = 1;
#if defined(CAMERA_MODEL_ESP_EYE)
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
// camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
sensor_t * s = esp_camera_sensor_get();
// initial sensors are flipped vertically and colors are a bit saturated
if (s->id.PID == OV3660_PID) {
s->set_vflip(s, 1); // flip it back
s->set_brightness(s, 1); // up the brightness just a bit
s->set_saturation(s, 0); // lower the saturation
#if defined(CAMERA_MODEL_M5STACK_WIDE)
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
#endif
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
startCameraServer();
Serial.print("Camera Ready! Use 'http://");
Serial.print(WiFi.localIP());
Serial.println("' to connect");
int raw_feature_get_data(size_t offset, size_t out_len, float *signal_ptr)
size_t pixel_ix = offset * 3;
size_t bytes_left = out_len;
size_t out_ptr_ix = 0;
// read byte for byte
while (bytes_left != 0) {
// grab the values and convert to r/g/b
uint8_t r, g, b;
r = resized_matrix->item[pixel_ix];
g = resized_matrix->item[pixel_ix + 1];
b = resized_matrix->item[pixel_ix + 2];
// then convert to out_ptr format
float pixel_f = (r << 16) + (g << 8) + b;
signal_ptr[out_ptr_ix] = pixel_f;
// and go to the next pixel
out_ptr_ix++;
pixel_ix += 3;
bytes_left--;
return 0;
void classify()
Serial.println("Getting signal...");
signal_t signal;
signal.total_length = EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_WIDTH;
signal.get_data = &raw_feature_get_data;
Serial.println("Run classifier...");
// Feed signal to the classifier
// Run the classifier
ei_impulse_result_t result = { 0 };
EI_IMPULSE_ERROR res = run_classifier(&signal, &result, false /* debug */);
if (res != EI_IMPULSE_OK) {
ei_printf("ERR: Failed to run classifier (%d)\n", res);
return;
// print the predictions
ei_printf("Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.): \n",
            result.timing.dsp, result.timing.classification, result.timing.anomaly);
#if EI_CLASSIFIER_OBJECT_DETECTION == 1
bool bb_found = result.bounding_boxes[0].value > 0;
for (size_t ix = 0; ix < result.bounding_boxes_count; ix++) {
auto bb = result.bounding_boxes[ix];
if (bb.value == 0) {
continue;
    ei_printf("    %s (", bb.label);
    ei_printf_float(bb.value);
    ei_printf(") [ x: %u, y: %u, width: %u, height: %u ]\n", bb.x, bb.y, bb.width, bb.height);
if (!bb_found) {
    ei_printf("    No objects found\n");
#else
for (size_t ix = 0; ix < EI_CLASSIFIER_LABEL_COUNT; ix++) {
ei_printf(" %s: ", result.classification[ix].label);
ei_printf_float(result.classification[ix].value);
ei_printf("\n");
#if EI_CLASSIFIER_HAS_ANOMALY == 1
ei_printf(" anomaly score: ");
ei_printf_float(result.anomaly);
ei_printf("\n");
#endif
#endif
static esp_err_t capture_handler(httpd_req_t *req) {
esp_err_t res = ESP_OK;
camera_fb_t * fb = NULL;
Serial.println("Capture image");
fb = esp_camera_fb_get();
if (!fb) {
Serial.println("Camera capture failed");
httpd_resp_send_500(req);
return ESP_FAIL;
// --- Convert frame to RGB888 ---
Serial.println("Converting to RGB888...");
// Allocate rgb888_matrix buffer
dl_matrix3du_t *rgb888_matrix = dl_matrix3du_alloc(1, fb->width, fb->height, 3);
fmt2rgb888(fb->buf, fb->len, fb->format, rgb888_matrix->item);
// --- Resize the RGB888 frame to 96x96 in this example ---
Serial.println("Resizing the frame buffer...");
resized_matrix = dl_matrix3du_alloc(1, EI_CLASSIFIER_INPUT_WIDTH, EI_CLASSIFIER_INPUT_HEIGHT, 3);
image_resize_linear(resized_matrix->item, rgb888_matrix->item, EI_CLASSIFIER_INPUT_WIDTH, EI_CLASSIFIER_INPUT_HEIGHT, 3, fb->width, fb->height);
// --- Free memory ---
dl_matrix3du_free(rgb888_matrix);
esp_camera_fb_return(fb);
classify();
// --- Convert back the resized RGB888 frame to JPG to send it back to the web app ---
Serial.println("Converting resized RGB888 frame to JPG...");
uint8_t * _jpg_buf = NULL;
fmt2jpg(resized_matrix->item, out_len, EI_CLASSIFIER_INPUT_WIDTH, EI_CLASSIFIER_INPUT_HEIGHT, PIXFORMAT_RGB888, 10, &_jpg_buf, &out_len);
// --- Send response ---
Serial.println("Sending back HTTP response...");
httpd_resp_set_type(req, "image/jpeg");
httpd_resp_set_hdr(req, "Content-Disposition", "inline; filename=capture.jpg");
httpd_resp_set_hdr(req, "Access-Control-Allow-Origin", "*");
res = httpd_resp_send(req, (const char *)_jpg_buf, out_len);
dl_matrix3du_free(resized_matrix);
free(_jpg_buf);
_jpg_buf = NULL;
return res;
static esp_err_t page_handler(httpd_req_t *req) {
httpd_resp_set_type(req, "text/html");
// httpd_resp_send(req, page, sizeof(page));
void startCameraServer() {
httpd_config_t config = HTTPD_DEFAULT_CONFIG();
httpd_uri_t capture_uri = {
.uri = "/",
.method = HTTP_GET,
.handler = capture_handler,
.user_ctx = NULL
Serial.printf("Starting web server on port: '%d'\n", config.server_port);
if (httpd_start(&camera_httpd, &config) == ESP_OK) {
httpd_register_uri_handler(camera_httpd, &capture_uri);
//httpd_register_uri_handler(camera_httpd, &page_uri);
delay(10);
i have an error : In file included from c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/common.h:29:0,
from c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/reference/integer_ops/pooling.h:21,
from c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/edge-impulse-sdk/tensorflow/lite/micro/kernels/pooling.h:23,
from c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/edge-impulse-sdk/tensorflow/lite/micro/micro_mutable_op_resolver.h:33,
from c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/edge-impulse-sdk/tensorflow/lite/micro/all_ops_resolver.h:19,
from c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/edge-impulse-sdk/classifier/inferencing_engines/tflite_helper.h:35,
from c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/edge-impulse-sdk/classifier/inferencing_engines/tflite_eon.h:28,
from c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/edge-impulse-sdk/classifier/ei_run_classifier.h:44,
from c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/fruitsclassification_inferencing.h:49,
from D:\Arduino\Basic-Image-Classification\Basic-Image-Classification.ino:8:
c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/cppmath.h: In function 'T tflite::TfLiteRound(T)':
c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/cppmath.h:26:35: error: 'round' is not a member of 'std'
#define TF_LITE_GLOBAL_STD_PREFIX std
c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/cppmath.h:32:12: note: in expansion of macro 'TF_LITE_GLOBAL_STD_PREFIX'
return TF_LITE_GLOBAL_STD_PREFIX::std_name(x);
c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/cppmath.h:35:1: note: in expansion of macro 'DECLARE_STD_GLOBAL_SWITCH1'
DECLARE_STD_GLOBAL_SWITCH1(TfLiteRound, round);
c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/cppmath.h:26:35: note: suggested alternative:
In file included from C:\Users\My laptop\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/esp32-hal.h:34:0,
from C:\Users\My laptop\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Arduino.h:35,
from D:\Arduino\Basic-Image-Classification\Basic-Image-Classification.ino:2:
C:\Users\My laptop\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib/math.h:278:15: note: 'round'
extern double round _PARAMS((double));
c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/cppmath.h: In function 'T tflite::TfLiteExpm1(T)':
c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/cppmath.h:26:35: error: 'expm1' is not a member of 'std'
c:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/cppmath.h:36:1: note: in expansion of macro 'DECLARE_STD_GLOBAL_SWITCH1'
DECLARE_STD_GLOBAL_SWITCH1(TfLiteExpm1, expm1);
C:\Users\My laptop\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib/math.h:290:15: note: 'expm1'
extern double expm1 _PARAMS((double));
Using library WiFi at version 1.0 in folder: C:\Users\My laptop\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
Using library fruitsclassification_inferencing at version 1.0.1 in folder: C:\Users\My laptop\Documents\Arduino\libraries\fruitsclassification_inferencing
exit status 1
Compilation error: exit status 1
Hello
before asking for help, do yourself a favour and please read How to get the best out of this forum and post accordingly (including code with code tags and necessary documentation for your ask like your exact circuit and power supply, links to components etc).
as a first step Please correct your post above and add code tags around your code
(Also press ctrl-T (PC) or cmd-T (Mac) in the IDE before copying to indent your code properly)
