I tried to make a 60 second led-diode timer and have it reset when i trigger the tilt sensor, but when i trigger the tilt sensor, it just stops the timer and doesn't start to count down from 60 again... does anyone know how i can fix this?
No idea whatsoever.
Mainly because you have not explained anything about what you are doing.
Not without seeing your code. Tell us what the code actually does and how that is different from what you want.
Read the forum guidelines and post your code.
Hello,
did you have implement a button to start the timer ?
Please forward your sketch to see what happens or not
